Had the first partially clear night in two weeks yesterday and also 3 moonless hours to burn so I packed my gear and went to my imaging spot.
It was my first time using guiding and polar aligning with a laptop, so that took a while but it eventually worked.
I originally planned to image the Sadr region but as soon as I had framed it up a lonely cloud appeared and made a beeline for....the Sadr region.
Really starting to miss having goto in my humble tracker (SWSA).
So I needed a new target. I'd already burned an hour of my 3 setting up and framing, so I decided on the blue horsehead which was just high enough at that point.
Framing that one went a bit faster and off I went.
Not wanting to "waste" more time experimenting I stuck to 30s exposures although I need to expose my histogramms more to the middle because I'm starting to fight with the sensor artifacts of my Nikon Z6II. I bumped ISO a bit and started imaging.
Total guding error was around 2" which is fine for my imaging scale of 4,88 "/px.
Total integration time is 1 h 24 min.
My ring artifact showed up again. Also colored concentric rings.
There would be a lot more details but I had to crop almost half the image to get rid of the ring and then sacrifice some detail to get the colored rings out.
In the short term I need to play with exposure parameters, see how far I can push exposure time and ISO but I'll probably look for a new mount soon. There are some GEM28 and CEM26 for around 1000 bucks used availabe.
Edited by Parcival19, 20 April 2025 - 10:13 AM.
