why is dss not stacking all of my subs.
15 replies to this topic
#1 uptomato
uptomato
Posted 20 April 2025 - 08:53 PM
I stayed up late to capture loads of images of the southern pinwheel galaxy. So I'm pretty unhappy. I've seen many posts about this and they say, change the star detection threshold and, make sure your in focus, make sure the star trails aren't too long, and I have always had some extent of star trails, but dss has stacked way worse than these images. Lately dss has not been stacking all of my frames a lot of the time, maybe a new update? I've even tried old data that worked then, not now, and now lets het back to the southern pinwheel galaxy. it's only stacking 61 compared to 300 and I've checked the frames it does not stack and they are fine, if not better that the ones it did stack. any help would be appreciated.
#2 bobzeq25
bobzeq25
Posted 20 April 2025 - 09:46 PM
Help. You may not like it.
DSS is an ANCIENT program that often causes difficulties for beginners.
The best cure is to drop DSS by moving on to a proper astrophotography processing program that calibrates/stacks/processes. My recommendation is Astro Pixel Processor. Many like Siril.
Pretty much all experienced imagers have done this, and no longer use DSS.
Edited by bobzeq25, 20 April 2025 - 09:47 PM.
#3 rj144
rj144
Posted 20 April 2025 - 09:52 PM
Post some examples of some autostretched subs.
Edited by rj144, 20 April 2025 - 11:18 PM.
#4 uptomato
uptomato
Posted 20 April 2025 - 10:06 PM
I am away from my PC right now, I will send some stretched subs, I have tried stacking in siril, I have tried siril with some frames, and it gives me a messed up result but siril is amazing for processing the linear image
#5 uptomato
uptomato
Posted 21 April 2025 - 01:25 AM
Didnt
This is one that it didn't dtack
#6 uptomato
uptomato
Posted 21 April 2025 - 01:26 AM
*Stack
#7 uptomato
uptomato
Did
#8 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 21 April 2025 - 01:37 AM
DSS is well known not stacking frames and usually it's because stars are not round enough.
If adjusting detection threshold doesn't help then you should get more round stars or use another software.
Others have mentioned recommendations already.
PS DSS is old but has its shortcomings but it's still actively developed.
PS2 I can't your example frames bigger ("You do not have permission to view this image").
Edited by Tapio, 21 April 2025 - 01:50 AM.
#9 uptomato
uptomato
Posted 21 April 2025 - 01:41 AM
Siril doesn't register them either, what can I do?
#10 uptomato
uptomato
Posted 21 April 2025 - 02:11 AM
Tapio. You should be able to view them now
#11 Tapio
Tapio
Posted 21 April 2025 - 02:16 AM
Thank you.
Clearly the image which didn't stack has trailed stars.
Not sure  if it's worth stacking so bad/trailed frames.
  • gsaramet likes this
#12 uptomato
uptomato
Posted 21 April 2025 - 02:49 AM
I've stacked worse frames than that with a good outcome is there any way to do it anyway.
#13 Tapio
Tapio
Posted 21 April 2025 - 03:10 AM
I've only used Siril few times but I know you can adjust the detection parameters.
Someone sure can give better/easier advice but I give you this (somewhat theoretical) link:
https://siril.org/tu...ls/dynamic-psf/
#14 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 21 April 2025 - 03:34 AM
I copied the OP's two images.
Loaded them into DSS, adjusted the Threshold, and they stacked:
Which apparently the "proper astrophotography processing program" couldn't.
#15 uptomato
uptomato
Posted 21 April 2025 - 10:29 PM
"proper astrophotography processing program"??
I used dss. I actually tried stacking those frames too and they stacked, but all together they do not only stacks about 60
#16 uptomato
uptomato
Posted 21 April 2025 - 10:30 PM
To be honest in the 60 images stacked there were decently big star trails so I think it was a lost cause
