Can you star collimate a primary and secondary with coma corrector installed? (Newt)
17 replies to this topic
#1 bokemon
bokemon
  • Loc: Silicon Valley, California
Posted 21 April 2025 - 05:35 AM
Hello folks,
I usually collimate with just a cheshire and laser.  But with all the drama I have been facing lately regarding thumb screws and focuser motion, I'd like to be able to collimate the scope with the closest to actual use configuration.  That means coma corrector and high power eyepiece.  For the primary mirror, I assume it is the same as an SCT?  Usually the seeing is too bad to view a star's airy disk, so I assume it is more like checking the concentricity of the poisson spot and secondary shadow rings?  But what about the secondary?  Is there a way to star-collimate that?
#2 mayhem13
mayhem13
  • Loc: New Jersey
Posted 21 April 2025 - 05:58 AM
Visual star collimation relies on precise axial collimation where the star is centered in the FOV. Where things get misidentified or misdiagnosed are typically issues with poor seeing or poorly figured optics.
Major secondary axis tilt and rotation should be mostly set and forget once….especially for imagers who need an evenly illuminated FOV. This can be difficult in F4 scopes whose secondary is offset for those that don’t recognize what to look for. Setting this should not invoke any optical elements at all and should rarely need adjusting.
Axial is another story……that can be done visually with a CC in place……but I’ve always found the barlowed laser method easier…..typically takes me under 2 minutes to perform with a stable secondary mirror and focuser.
#3 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 21 April 2025 - 07:30 AM
The reference for star collimation is tilting the primary optical axis and best focus location to the field center, so it's limited to primary axial alignment. There is no visual reference I am aware of that can reliably tilt the diagonal flat. Set it and leave it.
The star image is formed by the primary, so tilt the primary to center best focus for coma. Slightly defocus a star in the center of the field of view. The star should expand evenly to 1 concentric ring (as seeing allows) with the Poisson spot centered in it.
If the slightly defocused star expands asymmetrically then coma is present, and the best focus location is somewhere else. Tilt the primary so the star moves in the direction of the coma tail or asymmetric bulge. See Lockwood's collimation technique
Edited by Asbytec, 21 April 2025 - 07:33 AM.
#4 briansalomon1
briansalomon1
  • Loc: Oxnard CA
Posted 21 April 2025 - 09:54 AM
I align my primary mirror using both the diffraction pattern of a star and always leave paracorr in.
While I have the eyepiece/paracorr slightly defocused, and have decided where the rings are slightly nonconcentric, I'll stick my hand into the light path in different places until I have it directly over the nonconcentric portion, then I adjust the primary alignment screw or screws to "squeeze" all the rings into a perfectly concentric pattern. I find that's the easiest way to decide which screws need to be adjusted.
Lockwood says to "be critical" about how concentric the diffraction pattern is.
Edited by briansalomon1, 21 April 2025 - 09:58 AM.
  • Asbytec likes this
#5 dave brock
dave brock
  • Loc: Hamilton, New Zealand
Posted 21 April 2025 - 01:48 PM
I move the telescope to move the star from the field centre to the position in the field that gives the best collimation then adjust the primary to bring the star back to the field centre. If I had to move the scope, say, down and a little right, I know the mirror needs to be tilted up and a little left so it's obvious which bolts to adjust.
  • Asbytec and briansalomon1 like this
#6 bokemon
bokemon
Posted 21 April 2025 - 01:58 PM
ok, then
#7 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 28 April 2025 - 11:46 AM
Hello folks,
High power eyepiece--yes, for the primary mirror only.
Coma corrector--no.
No, a bit closer to focus, with perhaps only 2 rings showing outside the spot.
Photographically, yes.  Visually, no.
Why do you feel you aren't getting good collimation with the tools you have?  Could it be your laser is not collimated?
#8 152ED
152ED
  • Loc: Tehachapi, Ca
Posted 28 April 2025 - 06:50 PM
I used an old Lumicon coma corrector in my 10" f/5 dob for years, and was able to easily collimate the scope on a star with a high powered eyepiece, just like my SCT, with the coma corrector in place.  In a pinch (if I was lazy), it was possible to tilt the coma corrector slightly in its slip-fit holder to null out any on-axis coma, instead of tweaking the primary screws.
Now I just ditch the correctors and deal with fuzzy edges.  If I want a perfect wide field view I'll use a refractor.  :D
#9 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 28 April 2025 - 06:53 PM
I've done that, too. Move a star around the field looking for the best focus location. If you can find it at high power, it should show you where the primary axis is relative to your field of view.
#10 bokemon
bokemon
Posted 28 April 2025 - 08:15 PM
My laser is fine.  But when I put it in the focuser that uses only one thumb screw, I can make it flop back and forth in the drawtube (rotates along the thumb screw axis).  How am I to align the secondary when this happens?
#11 Neanderthal
Neanderthal
  • Loc: Springfield & Mountain View MO
Posted 28 April 2025 - 08:38 PM
Sounds like using a Howie Glatter Paralyzer would serve you well - it's designed to be secured into the drawtube with just one screw.
  • Starman1, Asbytec and manolis like this
#12 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 28 April 2025 - 10:15 PM
Absolutely. I use a Paralyzer for reasons related to its design, but it "pulls" my FarPoint laser in nice and firm. No room for any slop. The laser is nice and parallel to the focuser.
  • manolis likes this
#13 bokemon
bokemon
Posted 29 April 2025 - 04:21 PM
lol at "paralyzer" vs parallizer vs parallelizer.
This seems like a good device but in my case I can't use it because I am also using a 2" coma corrector.
Ideally, I would have a focuser drawtube with a built-in APM twist lock thing, with an also twist-locking 2" -> 1.25" adapter.  This is what came with my APM refractor.
Edited by bokemon, 29 April 2025 - 04:23 PM.
#14 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 29 April 2025 - 05:11 PM
The Howie Glatter Parallizer adapter would fit your coma corrector just fine.
It's a standard 2" to 1.25" adapter, but its design automatically centers the adapter in the scope and automatically centers the eyepiece in the adapter.
I attach the manual I wrote for its use, which has an illustration that explains it quite well.
#15 bokemon
bokemon
Posted 29 April 2025 - 05:27 PM
No, I mean the coma corrector will still get held in by the 1 thumb screw and flop around.
#16 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 29 April 2025 - 05:35 PM
So, what I do with my 2" adapter (in you case the coma corrector), is tighten all three screws if it has them. I also have a twist lock 2" adapter that holds my 1.25" Paralyzer. I use the single screw to set the Paralyzer then tighten the twist lock. I think that works. The Paralyzer is set, then tightened. Try that.
#17 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 29 April 2025 - 06:08 PM
Time to add a second thumb screw 120° away from the single one.
Two screws will fix anything in the focuser and prevent any wiggle.
  • Drill hole
  • Tap hole
  • Install thumbscrew (find anything at McMaster-Carr online)
#18 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 29 April 2025 - 06:20 PM
I never use my P when i collimate.
