I have recently been given a fairly old CGEPro mount which works fine with the nexstar+ handset.
I would like to set it up to connect to my laptop so I can control it from the computer. The mount has an RJ45 port labelled as PC, and I have a Lynx astro usb to rj45 rs232 serial port adapter which I use successfully with my Skywatcher HEQ5pro. (photos attached)
The laptop detects the serial port as com4. (photo attached)
However when I connect the cable to the mount and power it on none of the software installed on the laptop can detect a mount on com 4 (or any other com port). This includes:
1. CPWI
2. Nexremote
3. NINA
4. EQASCOM
I have scoured the Celestron support pages and the online PDF manual for the mount, but the only references I can find to connecting to a PC suggest connecting through the handset, and make no mention of the PC port...
Any answers (and supporting details) to the following questions would be appreciated!
1. Does the PC port provide connection for computer control (if not, what is it there for)?
2. Have Celestron used a non-standard implementation of of the RS-232 wiring, requiring a different cable?
3. Do I have to connect via the handset (which has an rj9 connector in the base of it) also requiring a different cable?
4. I also have an RJ11 to serial port adapter which would fit the same connector as the handset, should I be using that instead of the rj45 pc port?
