Took a long break, back at it since sun getting higher
Posted 21 April 2025 - 07:27 PM
Very nice!
Posted 21 April 2025 - 07:37 PM
Posted 21 April 2025 - 07:57 PM
Nice disk, a bit dark to fully appreciate, as seen from my airport lounge phone screen. If my phone is not misleading me, when returning to postings after a gap, then getting/guessing illumination right for display from ones backlit computer is often a challenge.
If you can click on the image it will take you to his site where there are 2 images. The first is a much brighter image of the same pic.
Posted 21 April 2025 - 08:50 PM
Posted 22 April 2025 - 06:18 AM
Looks good and I think you can pull the proms out in the positive image by pulling shadows up a bit since they show so well in the inverted image.
Posted 23 April 2025 - 01:42 AM
I use IMPPG, how do i do that with the curve feature?
Posted 23 April 2025 - 05:27 AM
In that case, you can’t just lift shadows. You will never have a smooth transition between the surface and the proms but you can develop curves to bring the proms out but there will be a sharp delineation (either dark or bright) depending upon how you put anchor points on the curve. I think Gary uses a curve that retains a positive image for the surface with bright proms. I would need to play with some images and do a screen capture to show you what I’m trying to describe. I think GIMP allows you to play with shadows and highlights but I’m not familiar with that program as I use Photoshop or Pixinsight to play with shadows.
Posted 23 April 2025 - 06:51 AM
Consider this PST image on the left from the 21st:
(click to enlarge)
It is a composite of 2 different tone curves in iMPPG. First, I create an sinusoidal tone curve that give me bright, white proms with an inverted disk. I save this as the "base". Then I reset the curve and create a 'linear' curve that brings out the detail on the disk in a normal form. After editing it in GIMP, I use the ellipse tool to select the disk only. Both the base image and this selected disk are pasted onto a PPT slide and I size the disk to fit inside, and on top of, the base image over the inverted disk. And viola the image above is created.
You could also just go directly from the first part into GIMP and invert everything there, but that will leave you with black proms and more of a "3D" gradient on the disk.
Posted 23 April 2025 - 08:02 AM
OK, not the greatest examples but here are some curves you can use, or you can process two separate images and then blend them, but you'll always have a sharp delineation between the disk and the proms, either dark or bright. None have been processed with any sharpening, etc, just bringing out the proms.
Curve for white proms/positive disk
Curve for dark proms/positive disk (probably the most frequently used but I'm not a fan of dark proms, jmo)
Shadows lifted in Photoshop
Posted 23 April 2025 - 08:38 AM
I call that the "hump" curve. It's the third variant I sometimes use.
Posted 23 April 2025 - 10:51 AM
I am currently developing a new routine that can be used in the next update of waveSharp that aims at highlighting proms in solar-images. Ive taken the liberty to take the original-posters image (kept the copyright intact) to show how this currently looks. This routine automatically spits the image in foreground/background and allows a special enhancement routine to show details in the fore and/or background. In this image I only have automatically pulled the background section forward.
EDIT: This is the documentation of the routine I used to show the proms https://www.aanda.or...aa45345-22.html
cheers
Cor
Edited by theaberrator, 23 April 2025 - 11:14 AM.
Posted 23 April 2025 - 12:22 PM
If anyone is interested I am looking to test-drive images. Unlike this example which was based on the 8bit PNG from this thread I do prefer 16bit unsharpened images. You can PM if you are interested in helping to develop this routine further.
Cheers
Cor
Posted 23 April 2025 - 01:01 PM
Looks pretty good Cor. It does exhibit what I see in most actions that attempt to separate proms from the disk getting that stark delineation between the proms and disk along with the typical bleed of dark areas of the proms that are at the base. I’ll try to remember to shoot some disks in 16 bit to send you as I usually always shoot in 8 bit. Faster fps and smaller files for animations.
Posted 23 April 2025 - 01:06 PM
Hi warren
Thanks up ahead for the files, you do not need to shoot in 8bit. It's the stack that needs to be 16bit.
On the edge"effect", this is a balancing act. If you want to see spicules for instance they should be a bit brighter. The current setup of this routine allows blending and dimming.
Cheers
Cor
Posted 23 April 2025 - 01:37 PM
That’s better. How do they look in grayscale? (Yeah, I’m one of those whose preference is without false color)
Posted 23 April 2025 - 01:43 PM
Now you’re talkin’! It also almost hides that stark division between the disk and the proms which would be there anyway in a single stack.
Posted 23 April 2025 - 01:45 PM
I like the descriptions of the colors. I have your software, I’ll play with it a bit more.
Posted 23 April 2025 - 01:46 PM
But you dont have the stuff I am developing which is brand-new, if you send a PM we can discuss this without "polluting" a thread.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
