Hi everyone!
I am new to Cloudy Nights and I would like to post a topic about something that's bothering me:
I have a Celestron Nexstar 130SLT that I wanna use for imaging.
I've got everything else I need for astrophotography (i.e. camera).
However, I have a slight problem..
My camera cannot reach focus with the telescope at all.
And after doing a lot of research, I apparently must modify the primary mirror.
The modification process involves moving the mirror forward with a set of bolts and other stuff.
It's easy to do and you don't need a lot of items.
But the problem is that I want to use my telescope for visual astronomy and imaging astronomy.
So when you modify the mirror, you can no longer use the telescope for visual observations.
I did find another way of achieving prime focus without modification.
All that needs to be done is simply adding a Barlow lens on the camera (With a T ring adaptor of course).
And this works fine.
However, when using my Barlow lens in combination with my DSLR camera, it makes my telescope more zoomed in.
This can severely cut off my field of view (FOV).
I captured a photo of the Orion Nebula and I couldn't get the entire nebula in frame.
Is there any other way I can try to get prime focus without using a Barlow lens or modifying the mirror?
By the way, my camera is the Canon EOS 450D
If you know anything, please let me know! I would HIGHLY appreciate it.
Thanks.
Edited by AstroLens-188, 22 April 2025 - 04:19 AM.
