quick question: putting on Bahtinov mask on my 9.25" sct
9 replies to this topic
#1 AEP64
AEP64
  • Loc: Just north of Tampa
Posted 22 April 2025 - 08:17 AM
I tried google but no luck on my question. I wanted to know if the mask lies on top of the little dow pins at the edge of the scope that the dust cover locks onto or do i slide the mask under them so it lies flat on the glass?
#2 james7ca
james7ca
  • Loc: San Diego, CA
Posted 22 April 2025 - 09:00 AM
It doesn't have to be very close to the corrector, so anywhere you can place it should be fine. On my refractors I but the mask on the front end of the dew shield (i.e. inches away from the objective).
#3 emflocater
emflocater
  • Loc: Clarkson, N.Y.
Posted 22 April 2025 - 09:03 AM
Yeah I put the 3 pegs on the outside of the tube or dew shield.
Cheers
Don
  • Dynan likes this
#4 AEP64
AEP64
Posted 23 April 2025 - 07:09 AM
Cheers
Don
so, you are slightly bending the mask to slip it under the 3 pegs so it sits flat, correct?  The mask i bought is the Tri bahtinov, but the star pattern doesn't look like what i see most have from google search and was thinking its either the type of mask im using or its cause i had it on the outside of the pegs. I am tempted to get a second mask ...a standard one for focus and save the Tri for collimation.
#5 james7ca
james7ca
Posted 23 April 2025 - 09:21 AM
You don't need to slip it under anything. Basically, anywhere you can place it should be fine.
That said, I've tried the so-called Tri-masks and I don't particularly like them for use when focusing.
  • AEP64 likes this
#6 AEP64
AEP64
Posted 23 April 2025 - 11:00 AM
my first time using one, and i am thinking i should have started off with the basic version for focus
#7 luxo II
luxo II
  • Loc: Sydney, Australia
Posted 23 April 2025 - 06:42 PM
Don't lay the mask on the glass - that's almost certain to lead to fine scratches in the coating.
There is nothing critical about Bhatinov masks, since they rely on diffraction, not refraction:
- it doesn’t need to be flat;
- tilted makes no difference;
- it doesn't need to be accurately centered;
- you can mount it at the end of a dewcap well in front of the scope;
- size is not important - eg putting a 6" mask in front of a 10" scope will still produce a perfectly useable pattern for focusing;
- the spacing of the bars is not critical - more (smaller) bars = stronger diffraction spikes, fewer = less diffraction.
Edited by luxo II, 23 April 2025 - 09:47 PM.
#8 AEP64
AEP64
Posted 23 April 2025 - 09:31 PM
Thanks for the information...I was concerned it doesn't seem to lay evenly (flat) on top of the pins that the dust cap attached to, but if that's ok, I rather go that route instead of taking a chance of scratching the glass.
#9 emflocater
emflocater
Posted 24 April 2025 - 01:22 AM
This video may help clear up any thoughts you may have. Click HERE
Cheers
Don
#10 OregonAstronomer
OregonAstronomer
  • Loc: Central Willamette Valley, Oregon High Desert and remotely from New Mexico
Posted 29 April 2025 - 05:33 PM
I have both basic and Tri- for my C8, C9.25 and C14. I like the Tri- for collimation, but once well collimated, I like the regular one much better for focusing.
  • Poochpa and AEP64 like this
