I didn't do any gradient correction. Yeah that Halo is driving me crazy, i wasn't sure what i needed to do with it
You have a few options. Multiscale Gradient Correction is the best as long as the image is covered by the MARS database (I'm not sure if this is). Next is probably the gradient correction process. Finally, the Seti Astro Script Automatic DBE is pretty good for most images. GraXpert gradient correction is also good, but I have noticed some odd behavior with it and only use it as a last resort.
I'd start with the Seti Astro ADBE and see where that gets you, then try other tools if that doesn't do well. Gradient removal should be one of the first things you do. I usually open the image, crop, BXT correct only, then gradient correction.
