I am posting in the experienced deep sky forum as I though it would be more likely to have members with rotators on their refractor rig. I can't seem to find forum posts on this topic, sorry if this topic has already been covered.
I am setting up a new rig consisting of an AP 1100GTO mount, SVX152 refractor with a Moonlight rotator / focuser, Stellarvue field flattener, ZWO OAG-L with a ZWO ASI 174mm, ZWO 7x50 EFW, and a ZWO ASI 6200MM.
My Esprit 100ED refractor rig also has an EFW and OAG, so the optical train is not symmetric in weight distribution (relative to the optical axis) as the EFW and OAG-L/guide camera stick out to the side. I don't have an electronic rotator on my Esprit rig, and don't rotate the optical train manually for different targets. I achieve third axis balance by adding a small weight to the top Losmandy plate. As the EWF/OAG stay fixed in position relative to the mount, the third axis stays in balance once set correctly.
On my new rig with the Moonlight rotator focuser, everything behind the rotator rotates together (i.e. field flattener, OAG, EFW, camera). I have not used an electronic rotator before.
The optical train behind the field flattener on the new rig with the rotator is similarly asymmetric in weight (relative to the optical axis) due to the EFW and OAG-L / guide camera. It seems that if everything behind the rotator changes position when rotating to different angles between targets, any precise 3rd axis balancing done in a different rotation position would no longer be correct in a new rotation position (the EFW/OAG-L would be rotated to a different position, changing the third axis balance point). I do automated imaging and don't plan on going out to the rig to tweak 3rd axis balance between targets captured at different rotation angles.
It seems the only solution would be to place an offset counterweight (relative to the optical axis) on the optical train behind the moonlight rotator to counterbalance the weight offset caused by the EFW/OAG-L. This "sum" balance with a counterweight correction should be the same regardless of rotation position, so any additional counterweight placed for 3rd axis counterbalance should remain correct regardless of rotation position. I have never seen this done in practice.
How do others with rotators and EFW/OAG deal with 3rd axis balance? Do people with Moonlight rotators just do what would be the "average" third axis balance on the Losmandy / Vixen plate and call it a day? Just ignore it?
