Hi friends,
I just had my C11 professionally cleaned and collimated and now I want to add a finder scope. It doesn't have a bracket so I bought a bracket and a 9x60 illuminated finder. My question is about placing the bracket. I take it that the three pairs of screws on the top of the OTA are to be used for mounting finder scopes or guide scopes, but I don't want to unscrew them in case I'm wrong and they are related to the placement of the primary mirror. Am I right about those screws being there for that purpose? Thanks in advance!
You should have two sets of screws on the rim of the scope at the back to mount a finder shoe. You can also add an ADM dovetail bar opposite the main dovetail bar to mount scopes or accessories. The bar would span the entire OTA. I use one to mount either a 66mm ED refractor or a 50mm guide scope in tube rings to my Edge 8.
One other idea is to mount a Telrad optical finder using a Telrad base with double stick tape to the OTA rather than a 9x60 optical finder. I personally prefer the Telrad to just about any optical finder.
Patrick
Edited by Patrick, 25 April 2025 - 12:42 AM.
