What is this crud in my flats?
9 replies to this topic
#1 Phanatic
Phanatic
Posted 22 April 2025 - 07:55 PM
Camera's a 2600MC Pro, and I started getting a whole bunch of crud in my image path.  Here's what it looks like on the 5" refractor:
At first I thought it was dew but it's in exactly the same position on different nights.  It's not on my filters, because it's still there without any filter.  It's not on the objective or the OTA because I swapped the camera over to an entirely different scope and it's still in the same place:
If I take flats with just the camera sitting there by itself, no scope, you can still see a blurry pattern of spots that look to be exactly the same debris except extremely defocused.  And I cleaned the cover of the image sensor itself and didn't have any impact at all.
I've seen that a batch of 2600s had oil leaks, but in the examples I've seen that doesn't look like this, and try as I might I don't see any of this stuff on the sensor under direct examination. (Although it does look like the oil leak on the shutter of my Nikon D600 like a decade ago.)
I guess this is a pretty dumb question because I think I've eliminated everything else it could be and it's got to be debris behind the cover of the camera sensor itself, but am I missing anything else?
  • Mike Phillips likes this
#2 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 22 April 2025 - 08:22 PM
Given the F/ of the scope(s) it should be easy to calculate the distance from the sensor to the crud.  It is probably on the camera window -- maybe on the inside.
There is also calculator tool here for dust spots... but it is easy to do on the back of an envelope too...
https://astronomy.to...tion_calculator
Edited by ngc7319_20, 22 April 2025 - 08:24 PM.
  • River Hills and ZigZagZebraz like this
#3 DeepSky Di
DeepSky Di
Posted 22 April 2025 - 09:12 PM
Could be on the flattener if you have one. Depending on the preview the flat may be stretched to show details. Just use it and evaluate results.
#4 Jared
Jared
  • Loc: Piedmont, California, U.S.
Posted 22 April 2025 - 10:16 PM
That is almost certainly stuff on the sensor window in front of the 2600 sensor.
  • bignerdguy and Spaceman 56 like this
#5 Spaceman 56
Spaceman 56
  • Loc: New Zealand
Posted 23 April 2025 - 02:21 AM
was anything else included when you did the swap or was it JUST the camera ?
#6 BucketDave
BucketDave
  • Loc: Bristol, UK
Posted 23 April 2025 - 03:28 AM
Looks like dust on the sensor cover to me. And tons of it. You say you cleaned it? Can you describe the process please?
#7 Brian Carter
Brian Carter
  • Loc: Atlanta, GA
Posted 23 April 2025 - 05:42 AM
That looks really bad and you can probably take your stuff apart and get it a lot better, it’s probably on the actual sensor window.
But as bad as it looks, flats will take care of all of it and you won’t see a bit leftover. So certainly fight the good fight against dust, but it isn’t the end of the world when you inevitably lose.
Edited by Brian Carter, 23 April 2025 - 11:16 AM.
#8 Phanatic
Phanatic
Posted 23 April 2025 - 01:48 PM
Just the camera.  In the flats above there is no flattener, filter, or anything else, the only thing the light goes through is the telescope lens followed by the camera.
Air bulb followed by Lenspen FilterKlear.  Whatever this is isn't on the sensor cover.  Not the front side, anyway.
#9 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 23 April 2025 - 04:14 PM
What is the F/ of the scope in the first image above?  Was there any reducer -- which reducer?
Edited by ngc7319_20, 23 April 2025 - 04:15 PM.
#10 rj144
rj144
Do your flats work?  If they do, I wouldn't do anything.
