Best Choice for 1.25 Diagonal
20 replies to this topic
#1 gustave
gustave
  • Loc: Charlottesville, VA
Posted 22 April 2025 - 09:02 PM
I want to take a break from 2” eyepieces and go with my 1.25 eyepieces. They are: TV 4.8 Nagler, TV 15 Wide Field, TV Nagler 26 Plossl, and a 40mm Celestron Plossl.  As well I have a William Optic binoviewer in which I use 24 Brandons.  The weak link is the diagonal that came with my 8Edge.  After shopping online I narrowed down to either the Tak or the Baader.
I’ve pretty much reduced my diagonal choices on what 1.25 diagonal to best match the above mentioned eyepieces.  They are: Baader Clicklock Dielectric, Tele Vue Everbrite, and the Takahashi 1.25" Prism.  Initially I wanted to go the TV but its reverse lateral image is not to my liking because it doesn’t match up with their recognizable images I’ve grown used to from years of observing and seeing in reference books.
I’m leaning toward the Baader, but there a temptation to go with the Tak given the brand’s excellent reputation and surprisingly competitive pricing.  One other concern I have is matching up to best support my bino’s weight.
Anyone care to weigh in?
Thanks for reading any thoughts you may have!
#2 cbowlsby
cbowlsby
  • Loc: California
Posted 22 April 2025 - 09:31 PM
All of these are good options.
The Takahashi prism is one of the sleeper options from what I’ve heard. When I did this I went the Baader route just because I like the convenience and security of the Clicklock mechanism and use it everywhere I can, even though it doesn’t always perfectly center the eyepiece.
#3 SeattleScott
SeattleScott
Posted 22 April 2025 - 10:10 PM
I like the Tak prism, but I don’t think I would love hanging a binoviewer off of it.
  • CrazyPanda likes this
#4 eyespy
eyespy
  • Loc: Western Canada
Posted 22 April 2025 - 10:27 PM
Hi Gustave,
I have three of the TAK 1.25” prism diagonals and have not been concerned about their construction or stability even when using a binoviewer. They do have an ‘ABS’ type plastic body but in over four years, this has not been an issue. The nosepiece and eyepiece connections are both metal.
Doug…..
#5 Mike W
Mike W
  • Loc: Upstate NY
Posted 22 April 2025 - 10:30 PM
Isn't the diagonal that came with the edge a mirror?
#6 c1ferrari
c1ferrari
  • Loc: SoCal
Posted 22 April 2025 - 10:54 PM
I seriously considered the Baader T-2 / 90° Astro Amici-Prism with BBHS® coating to complement a BP Mark V BV, but will purchase the Baader 2" / 90° Astro Amici-Prism with BBHS® coating as there are several 2" eyepieces that have piqued my curiosity.  I may still purchase the former Astro Amici-Prism and have a dedicated 1.25" eyepiece/BV rig.
#7 GSwaim
GSwaim
  • Loc: Planet Earth
Posted 23 April 2025 - 08:49 AM
I have both Tak 1.25" 90° prism diagonal & the Baader 2" 90° prism diagonal. Both are quite excellent. I use Brandon eyepieces but also have a TV 55mm Plossl. I only do visual observations of sun, moon, and planets using APO refractors.
The Tak prism may be the best for contrast & color on days/nights of seeing is best at the 4-5 range. Seeing at 4-5 is mostly rare however. Overall both are great and will depend upon telescope/eyepiece quality and seeing conditions.
Just my opinion.
Edited by GSwaim, 24 April 2025 - 05:21 AM.
#8 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 23 April 2025 - 09:42 AM
I want to take a break from 2” eyepieces and go with my 1.25 eyepieces. They are TV 4.8 Nagler, TV 15 Wide Field, TV Nagler 26 Plossl, and a 40mm Celestron Plossl.  As well I have a William Optic binoviewer in which I use 24 Brandons.  The weak link is the diagonal that came with my 8Edge.  After shopping online, I narrowed down to either the Tak or the Baader.
I’ve pretty much reduced my diagonal choices on what 1.25 diagonal to best match the above-mentioned eyepieces.  They are: Baader Clicklock Dielectric, Tele Vue Everbrite, and the Takahashi 1.25" Prism.  Initially I wanted to go the TV but its reverse lateral image is not to my liking because it doesn’t match up with their recognizable images I’ve grown used to from years of observing and seeing in reference books.
Uh, all the diagonals mentioned have the same image orientation--correct up/down and reversed left/right.
If you want a completely correct image, look for an Amici Prism diagonal.
Unfortunately, they have the "line" problem--because there is a split in the image, stars flare when crossing the center vertical line.
  • jrmacl likes this
#9 CrazyPanda
CrazyPanda
Posted 23 April 2025 - 10:44 AM
I can't speak highly enough about the Baader T2 Zeiss prism. Extremely sharp and high contrast. I used a T2 1.25" eyepiece holder, but I used a 2" nosepiece for a more secure connection and also to get the insides of the nosepiece as far away from the light path as possible for improved contrast.
It's robust enough to use with a binoviewer.
The weak plastic 1.25" Tak prism is not something I would add a binoviewer to.
  • cbowlsby likes this
#10 Mike W
Mike W
  • Loc: Upstate NY
Posted 23 April 2025 - 10:47 AM
Exactly, what's this reversed lateral image with TV Everbrite about?
  • jrmacl likes this
#11 cimar
cimar
  • Loc: California & Germany
Posted 23 April 2025 - 11:03 AM
The Baader T2 prism is optically very good and mechanically versatile.
  • GSwaim likes this
#12 Dobs O Fun
Dobs O Fun
  • Loc: KY
Posted 23 April 2025 - 11:12 AM
He just said it here
More info from a previous post here.
Also here
If you have any other questions please PM me.
#13 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 23 April 2025 - 11:57 AM
All 90° diagonals yield images right side up and reversed left to right, whether prism or mirror.
Only by adding an additional reflection can the image be corrected left to right, which is what happens in an Amici prism.
  • Mike W, Lagrange and CrazyPanda like this
#14 Mike W
Mike W
  • Loc: Upstate NY
Posted 23 April 2025 - 12:46 PM
Thanks Don, I thought so but wasn't sure.
#15 Bill Barlow
Bill Barlow
  • Loc: Overland Park KS
Posted 23 April 2025 - 02:32 PM
Another option is the Vernon Scope 1.25" dielectric quartz diagonal.  It has at least1/20 wave smoothness but costs about $550.  I bought one to use with my A-P 92 Stowaway and it is excellent.  I also own the 1.25" Tak and Baader T2 prism diagonals which I use in my slower (f/7.5 to f/10) scopes.
Bill
#16 mikeDnight
mikeDnight
  • Loc: Lancashire, North West England
Posted 23 April 2025 - 03:15 PM
 I use both the Tak and Baader/Zeiss BBHS prism's and find both to be excellent. I use a binoviewer and have no problem with either make holding the viewer firmly. The Baader has the advantages of interchangeable connections, for example, I sometimes use the Baader click-lock in 2" format with a reducer, or the Baader helical microfocuser 1.25". The Baader prism is oversized and if you chose the 2" click-lock and nose piece you could use a reducer for 1.25" while the prism will allow a 30mm 2" fit Ultraflat eyepiece to be used without vignetting should you choose to do so.
  • GSwaim likes this
#17 kasprowy
kasprowy
  • Loc: Chicago
Posted 23 April 2025 - 03:20 PM
I have a TV-76 with the 2" everbrite. When I pop a 1.25" Tak prism (same object, scope, eyepiece) in it's place, the Tak shows objects noticeably brighter.
Edited by kasprowy, 23 April 2025 - 03:21 PM.
#18 Lagrange
Lagrange
  • Loc: North West England
Posted 23 April 2025 - 07:30 PM
As far as I'm aware, the only Baader ClickLock Dielectric mirror is a 2" diagonal (I have one and it's great). You can use 1.25" eyepieces with it, but you need a 2"-1.25" adapter, and it's much larger and has a much longer optical path length than a 1.25" diagonal.
There are the T-2 Maxbright dielectric mirror diagonal, and the T-2 BBHS mirror diagonal which are both significantly smaller and can be configured to use a 1.25" nosepiece and accessories. Baader also make a couple of T-2 prism diagonals - a basic one and a more expensive Zeiss-spec model that can also have 1.25" accessories attached.
I've got the basic Baader T-2 Prism diagonal, and also the Tak 1.25" prism. I'm not sure I'd be able to see a difference between them in terms of image quality - they're both very good. The Tak prism is surprisingly solid and well made for something so lightweight, while the Baader is significantly heavier but more flexible in the ways that it can be configured.
The only real negative I've experienced with the Baader is that on a few occasions the nosepiece has loosened and partially unscrewed, resulting in the eyepiece and diagonal suddenly swinging down towards the ground. Thankfully the eyepiece didn't fall out but it gave me a fright each time.
Edited by Lagrange, 23 April 2025 - 07:36 PM.
#19 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 23 April 2025 - 07:57 PM
To avoid that, always rotate the diagonal to the right.  The eyepiece weight will tighten the nosepiece, then.
  • Lagrange likes this
#20 Lagrange
Lagrange
Posted 23 April 2025 - 08:47 PM
That's really useful advice and it explains why the problem occurred in the first place. I'm left eye dominant so I was probably giving the eyepiece a slight lean to the left without realising it.
#21 mountain monk
mountain monk
  • Loc: Jackson, Wyoming
Posted 23 April 2025 - 08:54 PM
My two cents… I have a 2” TV Dielectric mirror, a 2” Baader Amici prism (the $700 job), and a Tak 1.25”. I use the Baader for both 2” and 1.25” eps up to about 200x, and the “line” does not bother me at all. Above 200x I switch to the Tak prism with my Tak DZ and it is flat out marvelous. I use the TV mirror with my NP-101. I have not worried about the weight of eps with the Tak. No problem.
Dark, clear, calm skies.
Jack
