When I added the Takahashi FSQ 85 to my Esprit 150 I duplicated all the equipment, i.e. new tripod, mount, Eagle 5 computer, Primaluce Esatto 3 focusser, flattener, OAG-L, guide cam, ASI2600MM, Filterwheel and Antlia 3nm filters.
I now want to add a Takahashi TSA 120 and I am pondering the best approach.
Level 1 would be put a Primalucelabs saddle on top of the Eagle 5 XTM and swap everything above it
Level 2 would be buy the dedicated Esatto adapter for the TSA 120 (300 Euros for just the adapter), buy a new Esatto 3, new 86 to 72mm female adapter then replace everything behind it (flattener back)
Level 3 would be break it apart each time so just buy a new Esatto 3 adapter (did I mention that this costs 300 Euros?), buy a new Tak flattener, buy the appropriate spacers to give me the back focus and use my existing equipment from the camera, filter wheel and off axis guider.
I did not mention option 0 which is to buy another Eagle 6, then why not a third mount - for god's sake someone start an intervention.
Much of this will depend on how often I might swap between them. Also there are some very stuck elements in the imaging train.
My plan had been to shoot all spring and summer from France with the FSQ and the Esprit, running both rigs every night. I have left the Esprit and the 10Micron in France and used the Tak and the Warpastron WD20 this winter in England. However, my horizons at home are limited but a large number of protected trees in our garden so I do not have many nebulae to image and the Tak is reduced to 330mm focal length so not ideal for galaxies. Thus adding the TSA 120 to also travel between France and the UK to allow me to image more targets in winter.
How do you manage this. Are you less of a wuss and are confident you can label that 0.2mm spacer to give the Tak its correct back focus?
There is a joy in being able to drop the full imaging system into the saddle and start imaging. But surely there comes a point when we hit rock bottom and start to be sensible.
I would really appreciate your advice and Filippo is pacing anxiously as he waits to find out whether or not he can buy his second yacht.
