Hello everyone. For quite a while, I’ve been using a homemade solar filter made from a CD-RW disc to image the Sun. Yes, it works, but the quality is bad.
I’ve decided it’s time to get a proper solar filter.
There are two options:
1. Buy solar film
2. Buy an ND filter
Why doesn’t the first option quite work for me? Because I don’t have access to high-quality film — only some unclear Baader copy from AliExpress.
ND filters are easier to buy. I’ve already found one with 20 stops. However, I came across information stating that ND filters do not block infrared radiation, which can fry my camera sensor.
So it turns out that with an ND filter, i also need a UV/IR cut filter — and things aren’t so straightforward there.
For example, there’s the KG3 filter with the following transmission curve:
And there’s the QB21 BG38 filter, which has a narrower transmission curve:
Which filter is better for protecting the camera, and do I even need one at all?
Edited by Quark-Coder, 24 April 2025 - 06:19 AM.
