I see the mention of "aspherical" on eyepieces, which I read corrects spherical aberrations.
Afaik, refractors (like mine) don't have spherical aberrations.
Well no. The "aspheric" eyepiece is not trying to correct spherical aberration in the main scope. It is just another way to design an eyepiece. Sometimes a lens with an aspherical surface can replace 3 or 4 spherical lenses in a design. Aspheric lenses are getting cheaper to produce due to technical advancements, and are likely to appear in more designs as time goes by.
There are aspheric surfaces used to correct spherical aberration in scopes. For example the Schmidt corrector plate is an aspheric lens. Also the Newtonian primary mirror is usually a parabola, which is a form of aspheric. But these are a different situation than an eyepiece with an aspheric surface.
I've not been impressed with the Baader 41 mm and 36 mm. They in seem to be comparable to the Q-70 eyepieces to my eye.
I've been testing some wide field eyepieces for my new 80mm F/5 bino scope. I'm finding the Baader 36mm Aspheric eyepiece is marginally sharper than the Panoptic 35mm at the field edge in this scope, at least to my aging eye sight (no eye accommodation). I think in general the Panoptic is a superior eyepiece for edge sharpness, field flatness, and color correction. But in this particular case there seems to be some lucky cancellation of the field flatness issues, and maybe field edge astigmatism between the Baader Aspheric and 80mm F/5 lens. There also appears to be less field distortion in the Baader Aspheric during day time use. So the Baader Aspheric has its place. Did I mention the Baader Aspheric it costs about half of the Panoptic?
Edited by ngc7319_20, 24 April 2025 - 12:38 PM.
