Can one use an AT72EDII with say a 31mm Nagler or a 35mm Panoptic? Or will vignetting occur?
I asked TS Optics if a TSFLAT2 field corrector could be used with a 72 APO and they replied this:
"thank you for your interest. The TSFLAT2 will work with the 72mm f6 refractor. Working distance is 130mm but we suggest the corrector only for sensors up to 25mm diameter and smaller. Than you will have good stars also in the edges."
I replied to them asking:
Oh thank you very much, I will use it for visual widefield only. You think it will be good with eyepieces 40mm field stop?
and they replied:
"yes it will work. The Flattener should be adapted into the 2" Filterthread of the diagonal."
The recommended optical path length between the TSFLAT2’s M48 thread and the eyepiece focal plane for a 430 mm focal length scope is 128 mm. See https://www.teleskop...onnection-10307.
If you attach the TSFLAT2 to the filter threads on the end of the diagonal’s nosepiece, the resulting optical path length will be the OPL of the diagonal plus the length of the nosepiece. The OPLs of 2” diagonals are often in the 100-110 mm range, and nosepieces tend to run 25-35 mm. That would give you a total OPL of anywhere from 125-145 mm. It’s in the right ballpark which may well be good enough, and might be right on the money depending which diagonal you’re using.
For longer focal length refractors, the ideal OPL is shorter. That can require a diagonal with a removable nosepiece so the TSFLAT2 can be attached directly to the diagonal body, essentially replacing the nosepiece as described here: https://www.cloudyni...ual/?p=14016318
