I am a beginner. I was running my setup initially with ASI Air but decided to give NINA and CCDCiel a try. I've had trouble getting things running. I am running a mini PC with a Pegasus Gen 2 distributing power and USB services.
I can't get my filter wheel or rotator to connect. I have uninstalled everything and reinstalled just ASCOM and the camera and other ZWO driver package. I ran the ASCOM diagnostic program to see if it recognized the devices. The camera is recognized and shows up in Device manager as well. When I try to connect to the Filter Wheel I get the following:
Create Creating device
Connected Connecting to device
Error System.NullReferenceException: Object reference not set to an instance of an object.
at System.Dynamic.ExcepInfo.GetException()
at System.Dynamic.ComRuntimeHelpers.CheckThrowException(Int32 hresult, ExcepInfo& excepInfo, UInt32 argErr, String message)
at CallSite.Target(Closure , CallSite , ComObject , Boolean )
at System.Dynamic.UpdateDelegates.UpdateAndExecute2[T0,T1,TRet](CallSite site, T0 arg0, T1 arg1)
at CallSite.Target(Closure , CallSite , Object , Boolean )
at ASCOM.DriverConnect.ConnectForm.btnConnect_Click(Object sender, EventArgs e) in C:\ASCOM Build\Export\Diagnostics\ASCOM.DriverConnect\ConnectForm.cs:line 256
Dispose Disposing of device
Dispose Dispose is not implemented inthis driver
ReleaseComObject Releasing COM instance
ReleaseComObject Completed release. Count: 0
GC Collect Starting garbage collection
GC Collect Completed garbage collection
it seems that Object reference not set to an instance of an object is the problem. i have no idea what to do to fix this problem. Removing all programs and drivers and rebooting the mini computer did not work. Any advice?
