I attached the ZWO EAF to my Celestron EdgeHD 11 and tried imaging last night, and I’m now getting oblong stars.
My imaging train is: ASI2600MC Duo, ZWO 5x2 EFW, M54 manual rotator, 9mm M54 spacer, SCT to M54 adapter, 0.7x reducer — mounted on a ZWO AM5 and controlled using ASIAir. Backfocus should be exactly 146.05 mm.
Here's a picture of my rig:
I imaged before attaching the EAF to confirm backfocus and collimation, and saw fairly round stars (just a few dust spots). I manually focused and locked the mirror.
Here’s a picture before attaching the EAF:
I then took off the scope, attached the EAF, and ran a full cycle from 0–60,000 and back to test if it was working properly. I also checked backlash by moving 200 steps forward and back — it landed on the same spot, so I left backlash at 0. I cleaned the reducer glass (there was visible dust), and remounted the scope.
This time, I ran the autofocus routine using the EAF, leaving the mirror unlocked. Right after autofocus finished and I started imaging, I noticed oblong stars across the frame.
Here’s a picture after attaching the EAF:
I didn’t touch collimation, backfocus, or anything else in the imaging train. I have fans installed on the air vents, and waited up to an hour for the scope to cool down. Guiding was decent around 0.7–0.8" in both cases.
Is this how mirror flop usually shows up? Any pointers on how to diagnose and fix this would be appreciated.
