Is there a big difference in quality between the Celestron Omni 2x barlow and the Explore Scientific 2x Focal Extender? Has anyone done a comparison? Thanks!
Omni 2x vs ES focal extender 2x
#1
Posted 28 April 2025 - 04:57 PM
#2
Posted 28 April 2025 - 06:08 PM
I have not done a comparison.
The Omni is a barlow or telenegative. It is a cemented doublet that diverges the image.
The ES is a telecentric. It two cemented doublets one diverges the image the other re-parallizes the rays.
- The telecentric magnifying factor does not change with the eyepiece distance. (may not be an issue)
- The telecentric will not increase the eye relief. (may not be an issue, especially for older design eyepieces with short eye relief)
- The telecentric will not vignette low power eyepieces. (may not be an issue unless you are using with large field stops)
A great barlow is nearly invisible in the optical train. Like TV 2x. I also have a vingtage long barlow that is also very good. I used the Omni (GSO) on Jupiter and moon, it was not quite as good as the better barlows but just a whisker behind.
#3
Posted 28 April 2025 - 06:44 PM
The 1.25" Celestron Omni 2x badly vignettes my 26mm and 20mm plossls. Next time I'll try it with my shorter focal length Plossls.
Edited by JoeBlow, 28 April 2025 - 06:45 PM.
- vtornado likes this
#4
Posted 28 April 2025 - 09:51 PM
I'm impressed with the views through the sealed ES 2X FE. I like the fact that it doesn't double the ER of the eyepiece being used. The views using AT Paradigm/Agena Starguider ED's are excellent
#5
Posted 29 April 2025 - 03:14 PM
I never used the Omni, but the ES is excellent. I've never noticed any vignetting but I've only used it with a 32mm plossl once or twice.
#6
Posted 01 May 2025 - 09:03 AM
I have the 1.25 Celestron Omni 2x and the Celestron Xcel-LX 2x (more like 2.3x)
They both vignette my 24mm Panoptic, so I never used them with it because of that reason.
In my 100 degree set (20 Optimus - 13 Ethos - 9 Optimus - 7 APM - 5.5 ES - 4.7 Optimus - 3.6 Optimus) I have tried them with excellent levels of success! I can't use it with the 20 Optimus for obvious reasons but they work amazing in the 13E and all the way down. If there was any vignetting I didn't notice it.
In my old LER Set (31NT5 - 22NT4 - 17.5M - 14M - 12.5M - 9M - 6.5M - 4.5M) They did great in all of the Morpheus, which I no longer have .
I am sure there is better than the OMNI 2x but I was impressed with it. Can't beat the price for sure. The detachable lens cell also affords additional value and options.
-Victor
Edited by vrodriguez2324, 01 May 2025 - 09:04 AM.
