Purpose of Knobs on C9.25 Dovetail
8 replies to this topic
#1 Dart106A
Dart106A
  • Loc: West Texas
Posted 28 April 2025 - 09:27 PM
Okay -- newb question that has probably been asked, and answered -- but I cannot find it. Do these knobs on the front, and back of the dovetail of my Celestron C9.25 SCT serve a purpose other than preventing the OTA from sliding off the mount if the mount knobs become loose for any reason? I need to move my OTA forward just a bit more to get an ideal balance, but to do so I need to remove this aft knob. Probably a stupid question, but I'm new to SCTs.
Thanks, Mark
#2 Notdarkenough
Notdarkenough
  • Loc: 5000' ft @ 41° North
Posted 28 April 2025 - 09:29 PM
Safety stop, so the OTA can't slide all the through the clamps
#3 Dart106A
Dart106A
  • Loc: West Texas
Posted 28 April 2025 - 09:45 PM
So, essentially I need to do some risk management by removing this knob to obtain a correct balance for the OTA. Gotcha.
Mark
#4 Couder
Couder
  • Loc: Mansfield, Missouri in the Ozarks
Posted 28 April 2025 - 10:01 PM
you can put an allen bolt there, smaller head than the knob
  • Dart106A likes this
#5 Dart106A
Dart106A
  • Loc: West Texas
Posted 28 April 2025 - 10:06 PM
That might work. I'll have to try it to see if I can get the correct balance. Thanks!
Edited by Dart106A, 28 April 2025 - 10:09 PM.
#6 ris242
ris242
  • Loc: New Zealand
Posted 28 April 2025 - 10:40 PM
you are heavy at the back.......yes? .....so you could remove the back one and slide forward............the front one could therefore stay.
  • Notdarkenough likes this
#7 Kefka1138
Kefka1138
  • Loc: Looking up ~ 33°N
Posted 29 April 2025 - 10:48 AM
I had an OTA slip out on me once. Thankfully, I caught it in time but was scary AF.
#8 Dart106A
Dart106A
  • Loc: West Texas
Posted 29 April 2025 - 05:29 PM
The photo is of the aft knob. Yes, I need to remove/replace it so I can move the OTA a bit farther forward. The front knob is not in play at all.
Edited by Dart106A, 29 April 2025 - 09:15 PM.
#9 Notdarkenough
Notdarkenough
Posted 29 April 2025 - 06:00 PM
Using an EQ mount, your scope is pointed towards the North Celestial Pole (NCP). Unless you live on the equator, there is some angle your mount is pointed to. I am at 41° N, so my mount has a 41° angle from the horizon. When I mount my SCT, the OTA is at a 41° angle. The safety stops are designed to "catch" the OTA from sliding backwards from the mount clamps. Lots of rigs have a heavy back end - primary mirrors on an SCT, cameras, focuses, whatever - and have to ride the mount clamp at the rear of the mount to achieve balance. If your rear safety stop can't be used because that is where the mounting clamps are located, simply remove it. The other end should also be tapped for the same screw. Most dovetails don't have a "front" or "rear" end, they are bidirectional. So, they have the same safety stop at both ends, or at least the holes for it. You can put the stop in either hole, or don't use it at all; your choice. If there is some other problem, please attach a picture.
