For my birthday I got myself a 13mm Ethos for use with my C11 Edge with 0.7x reducer. I got this to split the difference between my 12.5 mm Morpheus and 14mm Morpheus as my “main eyepiece”, while giving wider field of views vs my 17.5mm Morpheus.
I had earlier tried the AT 13mm XWA but didn’t find it as comfortable in use as the Morpheus and it did not have as good of light scatter control. Enter the 13mm Ethos.
Don’t get me wrong, I love the Morphei. And you will see they are still in my line up, just I found myself switching between the 12.5 and 14, and then having to use the 17.5 to fit targets. So really it was about reducing number of EPs on my tray (three down to one ideally.)
Evaluation was done using my C11 Edge with 0.7x reducer, on galaxies in my home mpsas ~20.0 skies and dark site mpsas -21.9 skies. No clouds, no wind, transparency very good.
I do not wear glasses observing.
Note: I fully realize galaxies come small and come fairly large, some face on, some edge on, some bright mag 9, some mag 13. This is about finding the best ~2mm exit pupil ‘main eyepiece’ that is most useful across the spectrum on average. Of course if wanting to zoom in or out to optimally view a given galaxy, a different magnification could and would be used.
1) I first tried the 13mm Ethos vs the AT 13mm XWA, both with eye cups up. The Ethos was more comfortable (more eye relief, didnt have to press as hard to get full FoV) also it had better light scatter control when a bright star was near (not that the AT 13mm was bad). As far as image itself, the Ethos was a tad more “transparent” (ie could see a little more of the galaxies). So Ethos 13mm won over AT 13mm XWA. And the AT13mm XWA now awaits future sale. But that was expected.
2) Now the real tests:
Home Skies:
For comfort and crispness of view to the edge, I found the Morphei and Ethos both on par with each other. The 14mm showed a brighter image but due to light pollution it was more washed out and galaxies not as easily seen vs the 13mm Ethos. The 12.5 mm had higher contrast and galaxies were easier to see mainly because of punching thru the LP vs the 13mm Ethos. So 12.5 mm Morpheus stays my default home galaxy eyepiece.
Versus the 17.5mm, the 13mm Ethos had a wider field of view and if I was wanting a larger exit pupil I would just go to my AT 20mm XWA. So the 17.5mm really takes it on the chin, as I don't have a real use case for it on galaxies.
At dark site:
Since AT13mm XWA and 17.5mm were now both out of contention, it was just the Ethos 13mm vs Morpheus 14mm and 12.5mm. Again the 14mm while having larger exit pupil/lower mag showed a slightly brighter image, the Ethos showed more detail across more galaxies. Now using the 13mm Ethos vs the 12.5mm Morpheus, the extra mag that helped the 12.5mm in light pollution hurt it in dark skies. The galaxy extensions and arms were over magnified and not as easily seen on average vs the Ethos. So the Ethos 13mm is now my default dark sky site galaxy eyepiece. And again if lower mag/ more exit pupil is needed I will use the AT 20mm XWA.
Bonus eval: at home or dark site, on Milky Way targets (planetary nebula, open clusters, diffuse nebula, double stars), I also found the 13mm Ethos to be on average a better “main eyepiece” vs the 12.5mm Morpheus.
So my F/7 C11 Edge default line up is now:
Home: Pentax 40XW, ES 25mm 100, AT 20mm XWA, Ethos 13mm, Morpheus 12.5mm, 9mm, 6.5mm
Dark Site: Masuyama 50mm, Pentax 40XW, ES25mm 100, AT 20mm XWA, Ethos 13mm, Morpheus 9mm, 6.5mm
7 eyepieces for each (you can see why I had to free up the tray a little.)
Thank you to all those that chimed in on my earlier contemplation of getting the Ethos 13mm.
Jeff
Edited by ABQJeff, 29 April 2025 - 11:58 PM.
