Rouz Astro Tube Rings - New Sizes including Celestron C11
3 replies to this topic
#1 Rouzbeh
Rouzbeh
  • Loc: Canada
Posted 30 April 2025 - 01:56 PM
Rouz Astro Premium Tube Rings - New Sizes Added Including Celestron C11
  • 50+ Models & Sizes - Available for Takahashi, Astro-Physics, Celestron, Sky-Watcher, TEC and more...
Some Benefits:
  • LIGHTWEIGHT - less than half the weight of cast metal
  • IMPROVED RESULTS - significantly increases mount performance & image quality
  • CARBON FIBER COMPOSITE - CAD designed & produced using the FDM process (fused deposition modelling)
  • ARTICULATING DOUBLE HINGE  – powder coated stainless steel  - rings "wrap" around tube for extra grip
  • MACHINED KNOBS – CNC hollowed & knurled aluminum red (with hex bolt)
  • MODULAR DESIGN- various compatible & lightweight dovetails and handles
  • NO PAINT or ANODIZING- that can chip or be scratched off
STRENGTH:
  • STAINLESS STEEL RECEPTORS - all bolts threaded into implanted receptors
  • LOAD TESTED - for various scenarios with hundreds of pounds of load (see videos)
  • ENGINEERING GRADE MATERIAL - composite of high modulus carbon fiber & polymers fused at high temperatures over 540 deg F (no glue or epoxy is used)
  • EXTRA HEAVY DUTY - versions also available or 3x rings sets
Also Newly Introduced: New Hybrid Dovetail System & Ring Combo
Unique design aimed to reduce weight and allow various configurations:
  • Available in 3 Sizes:  8 inch/ 11 inch / 14 inch
  • High strength:  Aluminum alloy T6-6061 (aircraft grade, anodized)
  • Lightweight: Extensive CNC machining to reduce weight (up to 35% lighter than typical dovetails)
  • Unique Design: Allows for mixed top & bottom bar sizes, styles & materials
  • Repeating bolt pattern: Allows multiple positioning options (position top plates back/forward in 42mm increments)
  • Ultra lightweight combo: Pair aluminum bottom plate with carbon composite top accessory plate
  • Safety Stops: Add M6 bolts to either end to prevent accidental slippage
  • Multiple Bolt-Spacing System: Compatible spacing with most brands using M6 or 1/4-20 bolts
  • JoshH likes this
#2 Rouzbeh
Rouzbeh
  • Loc: Canada
Posted 30 April 2025 - 01:59 PM
Many combinations possible
#3 rprice
rprice
  • Loc: Tucson, AZ
Posted 04 May 2025 - 01:52 AM
Any plans for adding a size for the C14 / C14 EdgeHD?
Ron
#4 Rouzbeh
Rouzbeh
  • Loc: Canada
Posted 04 May 2025 - 10:19 AM
Ron
We've had quite a few request for the C14 as well and have a preliminary design.
Will look something like the one below in the extra heavy duty configuration with the double hinge to "wrap" around the tube.
Let us know if you are interested, would be happy to work on it with yourself.
