Hi everyone,
Currently I am using Askar SQA55 (264mm FL, f/4.8) paired with ASI2600MM and ASI533MC. While the wide field is nice for larger nebula, I am looking for more reach for smaller nebula and larger galaxies (M51, M101). I also have a C9.25 (2350mm FL, f/10), but the set up time with collimation and very narrow FOV is more frustating than I anticipated for imaging, so I am saving that for visual on planetary objects.
For narrowband imaging, I am using 3nm Antlia SHO filters, and the ASI533MC is usually paired with just UV/IR cut and L-Ultimate.
Mount is AM5 with counterweight. Seeing is average and I do most NB imaging at Bortle 9 at a park right in front of house. Since I am going back and forth during setup and breakdown, I would like to keep the rig to a reasonable weight. My backyard is covered by trees, may be what I really need is a new house . For OSC galaxies I would travel to a Bortle 4 area overnight.
Not too worried about tariff since I travel frequently and could carry back the scope purchase at a major discount as well.
I am looking for advice on what's a good FL to jump into, and based on my FOV simulation on SkySafari I am considering the following scopes. Would like to get your advice on the selection of any thing else I should consider.
Askar PHQ 107 (749mm FL, f/7) - could double as visual
Askar SQA 106 (509mm FL, f/4.8) - much faster so benefits for NB, but not much more reach than the SQA55
Sky-Watcher Esprit 100mm (550mm FL, f/5.5) - tried and true, but requires field flattener and calculating back focus while swapping cameras)
Sky-Watcher Esprit 120mm (840mm FL, f/5.5) - longest reach, but approaching what I would be comfortable in carrying with all accessories attached
WO Ultra-Cat 109 WIFD (518mm FL, f/4.8) - just released with little hands-on infomation
