Televue eyepiece comparison
56 replies to this topic
#1 Astromorris
Astromorris
  • Loc: South Carolina
Posted 30 April 2025 - 05:44 PM
Hello, i want to buy a new eyepiece, especially for better views of the hurcules globular cluster. I would like opinions from owners of either televues 2" 27mm panoptic eyepice or their 1.25 24mm panoptic eyepice. Thanks for your advice and clear skies.
  • scotsman328i likes this
#2 vtornado
vtornado
  • Loc: North East Illinois
Posted 30 April 2025 - 05:49 PM
What telescope will this be used in?
  • Jon Isaacs, scotsman328i and Tangerman like this
#3 Astromorris
Astromorris
Posted 30 April 2025 - 06:02 PM
8" dobsonian
#4 jrmacl
jrmacl
Posted 30 April 2025 - 06:03 PM
If you are choosing between those two, don't forget there is a new 24mm Delos coming, it's TFOV will be right in the middle of the 24mm and 27mm Pans (according to astronomy.tools):
https://www.televue....Tab=EP_EDL-24.0
#5 Mike W
Mike W
  • Loc: Upstate NY
Posted 30 April 2025 - 06:04 PM
Similar views but the 27 is a 2" and will unbalance your dob.
  • scotsman328i and GGK like this
#6 Astromorris
Astromorris
Posted 30 April 2025 - 06:05 PM
Thanks, im not a huge fan of the 100 degree eyepieces. I do appreciate the option though
#7 scotsman328i
scotsman328i
  • Loc: Charleston, SC.
Posted 30 April 2025 - 06:07 PM
M13 in an 8” Dob?
24 Pan I’d go with for the flatter field and slight increase in magnification. I’ve been told by others that the 27 Pan does have slight field curvature, but I’ve never looked through a 27 Pan. I own a 26NagT5.
#8 jrmacl
jrmacl
Then you will love the Delos, it is 72 degrees
  • Tangerman and Durkinphd like this
#9 scotsman328i
scotsman328i
Posted 30 April 2025 - 06:08 PM
No, the new upcoming 24 Delos is 72 degrees FOV. You’re thinking of Ethos.
#10 Astromorris
Astromorris
Posted 30 April 2025 - 06:10 PM
Your right, i was. Thanks. I will take a look at them.
#11 scotsman328i
scotsman328i
Haha Mike…yeah, that also.
#12 scotsman328i
scotsman328i
Posted 30 April 2025 - 06:13 PM
No worries! Yes, a few factors to count in…weight, field curvature, flat field, 2”-1.25” sizing, scope balance. I have an Orion XT8 Plus, the 24 Pan is one of my favorites to use in it.
#13 Astromorris
Astromorris
Posted 30 April 2025 - 06:17 PM
Ok thanks, is there a huge difference between a 1.25 and 2"
#14 Mike W
Mike W
  • Loc: Upstate NY
If you go for the 27pan I recommend the TV equalizer so switching between 2" and 1.25" won't unbalance your dob.
https://www.televue....d=23&Tab=_equil
Edited by Mike W, 30 April 2025 - 06:19 PM.
#15 Tony Cifani
Tony Cifani
  • Loc: North Carolina
Posted 30 April 2025 - 06:20 PM
Not the be the contrarian, but my best views of M13 are usually higher magnification, at least 100x. At a good dark site, you can really resolve some details. If your 8" Dob has a focal length of 1200mm, the 24mm Panoptic would provide 50x. Nothing wrong with this, I believe either of these eyepieces would be very fine choices. Maybe you already have decent medium power eyepieces like a 10-12mm?
  • Jon Isaacs, scotsman328i, HellsKitchen and 9 others like this
#16 scotsman328i
scotsman328i
Posted 30 April 2025 - 06:21 PM
Yes, the major difference is that a 2” allows for a wider field stop and thus a wider TFOV. 2” eyepieces are generally heavier and more expensive. There’s no downside to using 1.25” EPs, they’re just limited to a field stop that can only get so big, so the TFOV in a 1.25” eyepiece can only be so wide.
Edited by scotsman328i, 30 April 2025 - 06:21 PM.
#17 Astromorris
Astromorris
Posted 30 April 2025 - 06:23 PM
Ok i appreciate it
#18 scotsman328i
scotsman328i
Posted 30 April 2025 - 06:25 PM
Oh definitely not a contrarian. I agree. The OP was kinda deciding between the 24 and 27 Pan. Me personally?…
…M13 is INCREDIBLE in a 10 and 13 Ethos.
  • Tony Cifani and Tulsa like this
#19 scotsman328i
scotsman328i
Ok i appreciate it
#20 Mike W
Mike W
  • Loc: Upstate NY
Posted 30 April 2025 - 06:27 PM
Of the two the 24 will give a slightly better view of M13 because of the slight increase in power.
#21 hfjacinto
hfjacinto
    I think he's got it!
  • Loc: Land of clouds and LP
Posted 30 April 2025 - 06:37 PM
Neither of those 2 will give a better view of M13, you’ll get the best view with a higher power. I my 6” app which might have a comparable focal length to your dob (assuming 1200 mm) a 9 or 11 mm will give a tighter better view.
This is an actual view thru my 152.
Edited by hfjacinto, 30 April 2025 - 06:38 PM.
  • Jon Isaacs, BRCoz, scotsman328i and 4 others like this
#22 Mike W
Mike W
  • Loc: Upstate NY
Posted 30 April 2025 - 06:39 PM
I believe he means better than the plossl that comes with a dob. My best view of M13 in my 10" dob was 10mm Delos.
Edited by Mike W, 30 April 2025 - 06:40 PM.
  • scotsman328i and Procyon like this
#23 scotsman328i
scotsman328i
Posted 30 April 2025 - 06:41 PM
I agree. Whether with a dob or refractor, for M13 I always frame out at 10 and 13 Ethos.
  • Procyon likes this
#24 hfjacinto
hfjacinto
Still, at 1200 mm a 9 to 14 mm eyepiece will frame M13 better.
  • scotsman328i and Bob4BVM like this
#25 Mike W
Mike W
  • Loc: Upstate NY
Posted 30 April 2025 - 06:43 PM
I just said 10mm but that's not what he asked for. Everyone need a quality 24-30mm E/P.
