Hi all.
I've reserved a room at Hartness House for Stellafane this year. Since I was "retired" from JPL in November, I decided I want to drive the Prius (with a mere 258,000 miles on it) to Vermont from L.A. Should be doable in about a week each way. Lew Chilton has suggested I bring my Springfield with me and set it up outside the clubhouse. I think it'll fit in the Prius with the back seat folded down. At least the OTA and mount will. The tripod doesn't fold, but even it might fit.
I never really "finished" the scope. Made small modifications over the decades. The drive is from a Meade 2080 that I bought from Meade when I went to work evenings over Christmas in 1980 (I was working as a geologist at the same time, daytimes). I even have an RA circle somewhere in my "stuff" that was intended for the Springfield. At the time, though, I was fond of star hopping, and the two rosewood handles on the tube and the counterweight arm (added in the mid 80s), nicknamed "Armstrong Slewing Motors" made panning the skies while looking down into the eyepiece a blast. But I might try to put setting circles on the thing one of these days, maybe in time for Stellafane. Scope as configured in 1981 (posted from ATM by Robert - my copy of the mag burned in a house fire 24 years ago):
In this picture, taken at our Whittier house around the mid 1980s, I've replaced the finderscope in the counterweight arm with a Meade 4" Spotting Scope mirror lens, mounted to an adjustable guide scope mount with embroidery hoops. I long ago removed the spotter. It wasn't very good optically. Later, I found another spotter in great condition except the optical window was shattered. I could use the window from the one pictured here to put that one back on the road and rig up a new mount for it in the counterweight arm. The finders were simple Meade 60mm scopes. I've moved them to other projects, as they tended to need collimating every time I used the scope since they were under the OTA when sitting in the back of my van. Don't know if I'll put anything else on for a finder, versus just sighting along the tube corners, using a low power eyepiece, and the armstrong slewing motors to center objects (which works pretty well).
Here are more pictures of the scope, some partially dismantled, starting with this post:
https://www.cloudyni...ject/?p=3236821
