Just today I compared five eyepieces, a Bresser 35mm 70, a Panoptic 35, an AT 28 UWA, an Axiom LX 23mm and a Nagler 20mm type 2. I was using a C8 with a Celestron 2" diagonal and using a target that was 200 feet away with a printed grid pattern.
The Bresser 35 was only sharp in the middle third of the field while the Paanoptic 35 was sharp over 70-80 percent of the field,
The AT 28 UWA did pretty well, not quite as sharp as the Panoptic, but a distracting level of "ring of fire" in the daylight view. The Axiom 23 which preceded the Luminos 23 also had an obvious "ring of fire". I need to test these two again at night, but the ring of fire was distracting in both. Finally I compared the Nagler 20mm type 2, it was sharp most of the way to the edge with no ring of fire.
I should qualify these notes with the fact that my cataract surgery last year left something to be desired. I have a condition called Fuch's Dystrophy so my eyes aren't as sharp as they used to be. I picked up these eyepieces mostly used over the last couple years. This was the first time I compared them.
I like the Luminos 10mm, it's excellent. The Luminos 15 and 23 are so-so by comparison. The Axiom LX 23 has some good reviews but the old type 2 Nagler blew it away.
Second hand eyepieces can be a good value. Second hand panoptics can be a good way to go. The AT eyepieces do look like a good value as well.
