Mine was sent to Meade to repair work. I will start to use it now that the house is about all done. All my free time has gone into fixing the house so the county won't take it away.
good thing they saved you from dying in a fire trap.
cardboard is not allowed as a replacement for drywall in homes for wall finishes. While cardboard can be used for temporary patching or certain construction purposes, it is not a structurally sound or fire-safe alternative to drywall, according to InterNACHI®️ Forum and YouTube. Drywall is specifically designed to provide fire resistance, structural support, and a smooth finish for interior walls, whereas cardboard is more prone to damage and doesn't offer the same level of protection.
Why cardboard is not suitable:
Fire Safety:
Cardboard is highly flammable and doesn't offer the fire-retardant properties of gypsum-based drywall, according to Zehnder Clean Air Solutions and tytan.com.
Structural Integrity:
Cardboard is not strong enough to support wall loads or provide the necessary structural integrity for walls.
Moisture Resistance:
Cardboard is susceptible to moisture damage and can warp or deteriorate when exposed to humidity or water,
Pest Resistance:
Cardboard can attract pests like termites, which are attracted to the cellulose it's made of.
Building Codes:
Building codes generally require the use of fire-resistant materials like drywall for interior wall finishes.
When cardboard might be used:
Temporary Patching:
Cardboard can be used for temporary patching of small holes or gaps in walls, but it's not a permanent solution.
Construction Forms:
Cardboard forms are sometimes used in construction for temporary purposes, like holding concrete in place during pouring, but they are removed before the building is occupied.
Cardboard is commonly used for shipping and packaging items, but it is not intended for use as a wall finish.
Edited by starman876, 14 May 2025 - 06:51 PM.
