After a lot of testing and back and forth (thank you to everyone who put up with the bugs in the initial releases and for your feedback) I feel comfortable enough with the driver to say it's been officially released (only took until version 2.2!).
This driver will enable camera functionality for any software that supported ASCOM compliant cameras, allowing for plate solving, autofocus, automated sequences etc. with Fujifilm.
For processing, I would highly recommend enabling the function in the driver-specific ASCOM settings labeled "Save .RAF to SD Card." Right now, no software is equipped to handle the files NINA is saving from the camera, as it's raw sensor data without proper metadata for automatic detection of x-trans sensors. The ASCOM checkbox allows the camera to save your images right to its SD card in .RAF format, allowing your processing software of choice to properly debayer the files and work with them. Supported cameras are as follows:
GFX System:
GFX 50S
GFX 50R
GFX 50S II
GFX 100
GFX 100 II
GFX 100S
GFX 100S II
X Series:
X-H2
X-H2S
X-M5
X-Pro3
X-S10
X-S20
X-T3
X-T4
X-T5
This list of camera support is purely Fujifilm's decision, not mine, and there's nothing I can do to add to it. The SDK determines model support, so I'm stuck, but I think this is a decent list that should cover a lot of people. I might try to trick the SDK into working with some other models at some point, but right now that's all speculative. More information on functionality and support can be found at the github page.
In the meantime, you should be good to go to use Fuji cameras with your preferred astro software, and if you have any bugs feel free to reach out to me, some of the logs people have sent me have been invaluable for development.
Github (go to releases and use the newest one, right now it's 2.2): https://github.com/S...as1999/FujicomÂ
Clear skies
Edited by Scdouglas, 06 May 2025 - 12:45 PM.
