Hi all. I am curious if anyone knows how the slow motion mechanism works on a Zeiss Telementor T-1 mount. Seems to not be a geared system. Some sort of friction action. Thanks. Mark
Zeiss Telementor T-1 mount mechanism
#1
Posted 06 May 2025 - 10:03 PM
#2
Posted 07 May 2025 - 12:07 AM
Spring loaded tangential drive. Very simple and reliable.
Clear skies!
Thomas, Denmark
- Corcaroli78, Terra Nova and Bomber Bob like this
#3
Posted 07 May 2025 - 12:26 PM
It's been years... but, don't you have to "rewind" each axis? IOW, the system doesn't use a continuous 360* slo-mo gear, like my newer EQs...
- Terra Nova and Piggyback like this
#4
Posted 07 May 2025 - 01:24 PM
Yes, you have about half an hour's worth of slow motion in RA, after which you have to reset it. During normal observations, I almost never use the RA slow motion, preferring instead to push the scope along like an equatorial Dobsonian.
Clear skies!
Thomas, Denmark
- Piggyback likes this
#5
Posted 07 May 2025 - 01:46 PM
Clear skies!
Thomas, Denmark
So... my memory is better than I remembered -- good. The DEC Axis on my Mizar EQs has to be reset, too. Ditto for the 60-year old TAK S-1. Kenko got it right: the NES (& KDS-AZ) has 360* gears on both axes.
- AllanDystrup likes this
#6
Posted 15 May 2025 - 12:52 PM
Yes you do. Your memory is functioning correctly.
#7
Posted 17 May 2025 - 09:49 AM
The other major quirk with the telementor mount is that the numbers refer to the Hour Angle (HA) value, not the Right Ascension (RA) value, so you have to do an extra calculation to use them.
To use mine I set my watch to Local Sidereal Time, then HA=LST-RA, and if negative then add 24 hours.
- Astrojensen likes this
