I'm not really limited by the budget, however I'm a visual observer who usually uses simple AZ mounts like a DM4-type or Carton AZ with slow-mo (I was told AP used this to carry 5" refractor in the past), and I have EQ6 non-GoTo for tracking. So while I could sign up to buy the Mach 2, I don't need all the bells and whistles since I don't do astro-imaging, and the AP 6" f/12 will be used specifically for visual planetary observing. The local sky seeing condition is usually very good to excellent, I've seen the incredible planetary views sharp and unwavering at 600x on this AP 6" f/12 apo, the edges of the Encke Division was clearly defined across the whole ring at 600x.
I stay in an apartment (>85% of the people here live in high-rise apartment) so I will need a tall pier on wheels to move the mount into the lift/elevator as I'm unable to observe from my apartment. I'm past mid-fifties and have no problem to lift and carry my 22 inch f/4.1 primary mirror which weighs 20.5 kg. I'm still healthy to lift or carry something heavier but I will try to limit at 20kg or below for ease of use. Definitely not "forklift heavy".
A more portable mount is more likely to be useful, so the iOptron HAE69C which weighs 9kg and had payload 31kg without counterweight (or even iOptron HAE43C) seems appealing. Does anyone have experience using long refractor on a strain wave / harmonic mount?
Alternatively I'm also looking at a locally-available used mount. Regardless of which mount head I buy, I will need to buy or custom-build a tall portable sturdy pier on wheels.
I think AP900 would be more sturdy but less portable compared to the HAE69C or HAE43C. The AP900 may priced at twice the cost of a new HAE29C or HAE43C which I can self-collect in HK next month.
Currently I'm considering these few mounts, and also on the look out for other suitable mounts, especially if available locally. I would appreciate any comment or advice please.
Edited by Richard Low, 09 May 2025 - 10:13 AM.
