Most modern 32mm Plossl's have more ER, however the S4000 Meade SP32 's had a severely recessed eye lens, and those are the only ones I knew of that were not glasses friendly so I don't use them, however they worked great without glasses on, you could stick your eye right up there on them with no blackouts, but they are discontinued so you'd have to find them used, and they were about the 1.5" width you're looking for.
I'd suggest making the slip-on eyecup extenders with a sheet of craft foam from Walmart
This one is nice and comfortable with three layers thick, slides on and off whenever I need it.
1. Cut a length of the craft foam about 35mm width
2. Wrap it to fit end to end, then secure it with a piece of tape
3. Then test its ER, and slice off one little strip 1mm at a time until you get the right height
4. Then add one more layer around the test fitted piece that been accurately cut and glue it on and secure it till its dry
5. Add one layer on the inside, you'll have to measure because it'll be shorter than the other two because its going on the inside and its bottom edge will rest on the top rim of the EP that down inside the tube, these last two layers really add comfort/ thickness
my slip on eyecup slides on and stops when it hit the Celestron Omni's rubber grip ring, so its easy to get the right height every time it goes on.
