Hello everyone, I am getting a summer job in which I will make 2000 usd. I am considering using that money on a new telescope. I currently have an AM5 and wo gt81IV. I Would like to not get a new mount and still use the AM5, however I would consider selling the GT81. Let's say I have a 2,700 usd budget if I sell. I am still in high school so my parents are not dying to store a c14 in the garage, so I would be looking for something portable to an extent. I have loved the 81, so a refractor would be great. I want something with quite a bit more focal length than the GT81 though. I would love to keep both, but if there is a much better option and it's better to sell then I'm willing. I am really open to any options just keep rolling them out! I will also buy used so starting price can be over as long as I would be able to find it at my budget used, I'm willing to be patient and wait a bit for a good deal to come up.
Thanks in advance,
Isaac Metcalf
Issac,
You have a great system right now. Take the advice given above and be patient. In your patience research different scopes and cameras, take note of what they can do, FOV and cost.
Astronomy Tools will show you approximate FOV of just about any camera and scope out there, of almost any target.
https://astronomy.to.../field_of_view/
Your mount is a good one, do not sell it short. It should do a C8 maybe that C9.25, yes the counter weight shaft and counter weight will be needed, that's easy and okay. That can handle a 130mm / 910mm refractor with the counter weight installed. Pier extensions also, maybe two of them stacked.
When you jump up to a larger scope, more weight and focal length, secure the tripod - weigh it down or tie it down to the ground. Do not want it to spill over. Also, stability is king when it comes to long focal lengths.
To better understand astro imaging get this book,
https://www.amazon.c...d/dp/0999470949
it explains a lot.
Astronomy, not just imaging, is about your mount and tripod. Weight, focal length, physical size all affect tracking and pointing. Weight is just heavy, physical size - take into account a barbell and a dumbbell, both 20 pounds, a dumbbell is an easy one hand grab with good control, a barbell - same weight becomes a two hand grab because of it's length. Also, physical size could increase your wind resistance. Focal length, this goes to image scale, your tracking / guiding error needs to be less than your image scale. All mount related.
You have a capable mount, work with it, be patient, research. Don't let those images fool you, these people are magicians when it comes to imaging. They are very good at what they do.
Take this time to get that book, look into your dream telescope, see and realize what it is going to take to do what you want to do. Hobbies are very expensive AND unforgiving, astronomy is NO exception. Know what you want AND why you want it.
Focus now on you fundamentals, PA, pointing / guiding, imaging and processing. Maybe slip an eyepiece or two in and take a look. Lots to offer here.
Joe
