4mm Eye Piece Recommendation for a Small Refractor
68 replies to this topic
#1 CaribbeanCruiser
CaribbeanCruiser
Posted 11 May 2025 - 10:41 PM
OK, am I dreaming?  After spending the last, several, rainy nights reading through a few of the “The joy of a small refractor” posts and the countless replies, I find myself wondering if there’s a reasonably priced (sub $200US) 4mm eyepiece that has an equally reasonable exit pupil.
I bought my Z73 mainly for AP, but almost every time I take it out, my family wants to look through it, this is great!  The trouble is,  I only have a decent 12mm (Celstron X-Cel) and an OK 9mm Plossl that came with a cheap scope.  Both throw up some nice views of our moon and the moons of Jupiter, but I’d really like to show them some detail on Jupiter and the rings of Saturn.
4mm, roughly 100x, would seem to be more than enough.  Maybe 80x, roughly 5mm is enough and a little more comfortable?
#2 NOLAMusEd
NOLAMusEd
  • Loc: Louisiana
Posted 11 May 2025 - 11:05 PM
A 73mm scope should have no issue with 100x or even more. Consider a 2x barlow lens or telecentric focal extender to take the 12mm to 6 mm and the 9mm to 4.5mm. If you're set on an eyepiece, a used Radian of 4mm should give nice views on bright objects like Saturn, Jupter, luna and not be too expensive. The drift time shouldn't be too bad either since it won't be very high magnification, and it should be plenty comfortable with its long eye relief. You could also pair it with the barlow for 200x which would be starting to push the limits of the scope, but should still be workable with bright objects when seeing permits.
  • Dave Mitsky, Kutno and CaribbeanCruiser like this
#3 MrsM75
MrsM75
  • Loc: 34° N, 117° W
Posted 11 May 2025 - 11:07 PM
A small Refractor so I'm guessing it fast f/5 scope, it will not be forgiving in eyepiece than a f/15, plus eyepiece of 4mm is not a magnification that a cheap eyepiece can achieve good view with a fast scope.
I really can't recommend any cheap 4mm eyepiece with a fast Refractor.
I think you should get a 4mm Delite Televue, or a 4mm Vixen SLV Lanthanium glass. Or the 4.5mm Delos Televue.
Delos is 72 degrees. And it Televue, who doesn't love it.
  • CaribbeanCruiser likes this
#4 havasman
havasman
  • Loc: Dallas, Texas
Posted 11 May 2025 - 11:11 PM
If that's the William Optics scope a 4mm eyepiece yields a 0.7mm exit pupil and that can be difficult for relatively inexperienced observers. Consider an Astro-Tech 7mm UWA, a very good eyepiece that will be much more user friendly. It will also make enough magnification to show what you want if you'll take the time to build observing skill and patiently ferret out all that combo will show you.
  • Procyon, ABQJeff and CaribbeanCruiser like this
#5 Matthew Trail
Matthew Trail
Posted 11 May 2025 - 11:13 PM
A Celestron Xcel LX 5mm (apparently really 4.5)? I have one on the way but haven’t viewed through one. I like my 4mm Radian in my TV 85 and you could find one used in that price range. 5mm Paradigm gets good reviews and is well within that price range too. My TMB planetary II clone (Svbony brand) is also a great value. It’s labeled 4.5 but I suspect it’s closer to 4mm—perhaps even mislabeled.
You’ll probably want an eyepiece with good eye relief for family viewing, and all of the above would do.
#6 Mike W
Mike W
  • Loc: Upstate NY
Posted 11 May 2025 - 11:14 PM
Televue radian
  • Kutno, eblanken and CaribbeanCruiser like this
#7 Jay_Reynolds_Freeman
Posted 11 May 2025 - 11:22 PM
Before you spend piles of money on more modern types, look for used orthoscopics. They will likely do reasonably well at f/5. Perhaps you won't want anything fancier.
Clear sky ...
#8 Ernest_SPB
Ernest_SPB
  • Loc: St.-Petersburg, Russia
Posted 11 May 2025 - 11:26 PM
Consider also TMB Planetary
  • BillinBallard, Jon Isaacs, Vostok and 1 other like this
#9 Jon Isaacs
Posted 11 May 2025 - 11:34 PM
The WO ZS73 is a ~72 mm F/6 FPL-53 Doublet.
I had a real 4 mm TMB Planetary, it was decent at F/6.  The 4 mm Astro-Tech UWA is a pretty good eyepiece and I believe it's $120.  I use the 5 mm Paradigm quite a bit. It's quite good at F/6 as well.
  • zjc26138, Mark Lovik and CaribbeanCruiser like this
#10 MisterDan
MisterDan
  • Loc: Colorado
Posted 11 May 2025 - 11:38 PM
I agree with Ryan.  One 2x Barlow or telecentric amplifier => two "new" eyepieces.
Best wishes and luck.
Dan
  • therealdmt, NOLAMusEd, eblanken and 1 other like this
#11 T1R2
T1R2
  • Loc: Little Rock, Arkansas
Posted 11 May 2025 - 11:43 PM
Shoot for 146x-ish+, and another EP that gives about 20-30x over that, the formula for finding any telescopes highest theoretical max power is its "aperture in mm's x2" ,  so 73mm scope is 146x, if you can only find an EP that gives 150x thats fine also. but don't expect magic in a 70mm scope seeing details in Saturn's rings requires at least 5" (maybe a 4" scope)  and 250x+ and with that you can just start to see Saturn shadow etched across the backside of the rings, Cassini's Division will be visible in a small scope but the sky has to be really steady.
But don't expect much since Saturn's rings are edge on for the next 3 yrs at least until they start opening up real good again.
Edited by T1R2, 11 May 2025 - 11:44 PM.
#12 MrsM75
MrsM75
Posted 12 May 2025 - 12:25 AM
I would still get a $200ish range 4mm brand name ep OP, your Williams Optics is too precious for a cheap eyepiece.
  • eblanken and CaribbeanCruiser like this
#13 triplemon
triplemon
  • Loc: Portland, OR
Posted 12 May 2025 - 12:56 AM
A 4mm ortho ? I call those contact lenses ... barely 2mm eye relief. That is REALLY for hardcore folks only and not a family-have-a-look thing.
If you like the 12mm X-Cel LX, get the 7mm version. Maybe plus a 2x barlow. As that easily fits your budget and you know exactly what to expect. The 5mm in that series has a poor reputation, so I'd have some reservations. With the 7mm + barlow, you get 65x and 130x, which both make sense with that telescope. Plus the barlow might make the 9mm Plossl a lot more useable as a 100x eyepiece, as the barlow will increase its eye relief notably.
Edited by triplemon, 12 May 2025 - 01:08 AM.
  • Jon Isaacs, Alan French, vtornado and 3 others like this
#14 izar187
izar187
  • Loc: 43N
Posted 12 May 2025 - 12:59 AM
Consider perhaps a 4mm Siebert SS4
68º fov with 17mm eye relief, less than 1mm recessed.
Call and talk to the man who makes the ep before ordering.
https://www.sieberto...rtho page).html
Edited by izar187, 12 May 2025 - 08:51 AM.
#15 SeattleScott
SeattleScott
Posted 12 May 2025 - 01:03 AM
For sharp views on a budget, a vintage 3.8mm Parks Gold/Orion Ultrascopic. However only 7mm or so ER and vintage 50 AFOV.
The 4mm Radian might just be the ticket, long ER, decent AFOV and under $200 (probably around $150).
New, I would say the 4mm AT UWA. Fast, before tariffs double the price. Or a Vixen 4 SLV if you can find one around $100.
#16 MrsM75
MrsM75
Posted 12 May 2025 - 01:15 AM
The Vixen 4mm Lanthanium glass it everywhere it just it retail price of $146.95 (Explorer Scientific) and other sites all has them.
You could have get them for $105 at Amazon Japan, but starting midnight of May 1st Amazon Japan has taking down  telescopes to eyepieces that 'Made in China'.  No more $100 Vixen SLV at Amazon Japan anymore.
The thing is 4mm is hard to get sharpness to the edge unless it a premium eyepiece, or if you have like f/20 scope.
And for OP "William Optics" brand Refractor, it too precious to get $50 range eyepiece anyways. I go for Televue.
Sorry No to 4mm Orthos or 4mm Plossl, no please, it literally like a peep hole so tiny to look through, I salute all those who can look through those in 4mm magnification.
Edited by MrsM75, 12 May 2025 - 01:17 AM.
  • triplemon and CaribbeanCruiser like this
#17 MrsM75
MrsM75
Posted 12 May 2025 - 01:23 AM
I am sorry this is  4mm Ortho, am I missing something? Are there like a 100 degree Ortho for bigger hole? 4mm Plossl it like this too, how can anyone look into a tiny tiny hole like this?
  • zjc26138, triplemon and CaribbeanCruiser like this
#18 Tropobob
Tropobob
  • Loc: Cairns Australia
Posted 12 May 2025 - 02:31 AM
I suggest buying an economically priced 2x barlow and using it with both the 9mm & 12mm eyepieces.  Barlows work pretty well these days, providing its not a cheapie that was packaged with a beginner's scope.
  • MisterDan, triplemon and CaribbeanCruiser like this
#19 Jay_Reynolds_Freeman
Posted 12 May 2025 - 03:26 AM
The eye relief is very small, but many of us have been using them for years with no difficulty, they are inexpensive used, and they do work reasonably well at fast focal ratios. Notwithstanding, "Try before you buy" is always good advice.
Clear sky ...
Edited by Jay_Reynolds_Freeman, 12 May 2025 - 03:27 AM.
  • John Huntley, MrsM75 and CaribbeanCruiser like this
#20 Procyon
Procyon
  • Loc: 37º N | 45° N
Posted 12 May 2025 - 06:31 AM
4mm Takahashi TOE
The board below is claiming Pentax XO performance in a more comfy and larger AFOV setting.
Also: 4mm Radian or 4.5mm Delos.
Edited by Procyon, 12 May 2025 - 06:47 AM.
  • ABQJeff and CaribbeanCruiser like this
#21 davidgmd
davidgmd
  • Loc: Maryland
Posted 12 May 2025 - 08:32 AM
For occasional, inexperienced observers (family members taking a peek now and then): 4 mm DeLite for ease of acquiring and maintaining the exit pupil.
  • eblanken and ABQJeff like this
#22 ABQJeff
ABQJeff
  • Loc: New Mexico
Posted 12 May 2025 - 08:35 AM
Best bang for buck and under $200: AT/APM/Stellarvue/Meade (pick your label, they are the same eyepiece just in different jackets) 4mm 82 degree. Nice wide field of view if you choose to go manual.
Over $200….
Best no compromise high mag performance, Takahashi TOE 4mm. Narrower FOV but some of best on axis/high mag performance.
Next best with a little more eye relief and field of view: TV Delite 4mm.
  • davidgmd and triplemon like this
#23 rgk901
rgk901
  • Loc: Beautiful Bortle 10 Midwest Skies
Posted 12 May 2025 - 08:45 AM
4mm AT UWA
5mm AT paradigm
xcell 7 (6.5)
+ 2x/1.5x Barlow for versatility
or
svbony 6 element 7-21 zoom plus the barlow
or
svbony 3-8 zoom
or
used 4.5 (4.8) Morpheus
*the exit pupil size is measured by focal ratio / eyepiece focal lenght so a 4mm/f6 = .66
Edited by rgk901, 12 May 2025 - 03:40 PM.
  • zjc26138, therealdmt, sevenofnine and 1 other like this
#24 GGK
GGK
  • Loc: Southwest Florida
Posted 12 May 2025 - 09:13 AM
WO Z73, f/5.9. 430mm focal length -- My closest similar scope is an AT60ED, which is 60mm / 360mm at f/6.  For a 4mm eyepiece for guests at 90X, I select the 4mm TV Delite.  I fully extend the adjustable eyecup, tell them to find the image first, then push down on the eye cup until the field stop is visible and twist to lock in place.  It's easy for them to use every time with or without glasses. A used 4mm Delite is likely around $200.
For some guests, though, the 0.67mm exit pupil in the AT60ED is getting a bit dim (will be brighter with your 73mm aperture),  so I keep a 5mm available too, which is just as easy to use.  I'll also note that many guests prefer the larger diameter eye cup and eye lens of the 4.5mm Delos as well as its wider field of view.  The process to adjust the eye cup for easy observing is the same as the Delite, but the Delos will be more than $200 used.
Gary
  • eblanken likes this
#25 MisterDan
MisterDan
  • Loc: Colorado
Posted 12 May 2025 - 10:57 AM
Yes - lots of us can and do use 4mm & 5mm Abbes & symmetricals.
Cheers.
Dan
