Clownpants,
As you can see, there are as many suggestions about eyepieces are there are eyepieces (or people on Cloudynights.com)
That's because eyepieces are such particular things.
Personally, I'd avoid the zoom eyepiece options. They are, generally, not as good. There are some very good zoom eyepieces, but the very good ones are not in your price range.
I also like the Paradigm 5mm and 12mm eyepieces from our sponsor, Astronomics. These two are really quite good, although not all of the line perform as well as these. So long as you don't wear glasses for astigmatism and don't need a whole lot of eye relief, these are good choices. From the Celestron XCel LX line, I recommend the 7mm (really 6.5mm), the 9mm and the 25mm. These three are quite good, extraordinarily good for the cost-benefit ratio. BTW, the Meade HD-60 line of eyepieces (no longer on the market new) can sometimes be had in the CloudyNights.com Classifieds, and are the equivalent of the Celestron XCel LX eyepieces, but stick to these focal lengths. Again, like the Paradigms, this line is not universally good, with a few poor performers as well as some that are just okay. These three from the Celestron or Meade lines, however, are quite good and represent a very good value, like the two Paradigms, 5mm and 12mm.
But a different path, and probably the best one, is to go ahead and get the AstroTech 7 & 10mm UWAs. These two don't cover as much ground, magnification-wise, because the 7mm is really an 8mm eyepiece, so you're getting 8mm and 10mm eyepieces, but with the huge true field of view they'll put into your eye, you will be quite happy with the result in your 8" dob. Although together they'd cost just a little over your budget, with your CN discount they won't be much over it.
I also recommend a good 2" widefield eyepiece. Without a doubt in my mind, the AT 28 UWA from our sponsor is one of the best deals going, bang for the buck, in widefield eyepieces. It will cost more than your budget by itself, but it is definitely one of the most valuable things you could upgrade your scope with. You won't believe what it can do.
Good luck and welcome to CloudyNights and the wonderful world of astronomy.
