Looking Great. We also have the Lunt 100mm mtds scope and hope to start imaging soon. Don't yet have a camera. We'll borrow some from the Milwaukee Astronomical Society and start experimenting.
I've mostly done deep sky and a little lunar/planetary imaging but solar is something I've only tried over the past year. In that time I've accumulated a Quark Chromosphere filter, the Lunt100MTDS and a Lunt40 double stacked scope. Learning to tune the Quark was difficult as I had the misconception that proper tuning would be near the middle of the tuning knob's range (actually it was much more to the left or bluer wavelengths for me so far). The Lunt pressure tuned etalons used double stacked were a real challenge for me to get right, and I still may not have it quite right after a year. But the tilt tuned front stacked etalons on the Lunt 40 (used double stacked) are much easier to figure out. Now I'm trying to use both the Quark and the Lunt 40mm etalon simultaneously on several of my refractors. It all takes time.
I know how to use the Lunt100MTDS pretty well in the native double stack configuration without a barlow. When I add a barlow, for some reason that I still don't quite understand, I get unwanted shading usually in two broad swaths, across my camera FOV. It happens no matter which camera or which barlow I use. They are not caused by Newtons rings. If I can eliminate these shadows, then I'll feel happy that I finally know how to use the Lunt100MTDS... but I'm not there yet.
Good luck with your solar imaging. I think you will want a monochrome camera. For full disk images at F/7, maybe something like the ASI178MM which has a pixel size of 2.5 microns is an OK compromise although I think there are better choices that I haven't tried yet. When I add a barlow lens for F/17.5 or F/21 (if the seeing allows it and I want more of a close-up view) I've been using my ASI174MM which has larger pixels at about 5.86 microns although I think there are better choices. I'm finding it isn't necessarily just a matter of matching focal ratio to camera pixel size. Available ROI sizes and camera speed and noise seem important considerations as well. Nothing in life is simple. Sooner or later I'm going to look into these Player1 cameras etc. that solar imagers seem to gravitate towards.
Rick
