I followed a suggestion to record in 8-bit, instead of 14-bit for my hydrogen alpha setup (Lunt 60mm, Touptek G3M178MM), and that did double my FPS, which is good. However, I noticed during stacking that the 8-bit images took considerably longer to stack in AutoStakkert, and I can't figure out why. Does anyone have an explanation? It's not bad if I only have a few videos to stack, but when I get lucky enough to have hours and hours of clear skies in one day, I can't even finish stacking on the same day.
With a short break in the clouds today, I did a little experiment with fresh recordings and have this data that shows the difference. Both videos were 800 frames, and I stacked the top 20%.
8-bit 14-bit
Surface stabilization 52.0 5.7
Buffering and Analysis 60.0 7.7
Reference Frame 6.6 4.2
Alignment 23.7 10.6
Stacking 10.6 5.1
MAP Analysis 1.6 1.5
MAP Recombination 1.2 1.1
In summary: for 8-bit: ~30 seconds to record, and 2.5 minutes to stack. For 14-bit, ~60 seconds to record, and 36 seconds to stack. All settings in Autostakkert were the same between the two stacks: Surface, disable stab=unchecked, improved tracking=unchecked, find anchor=checked, expand, quality estimator=automatic, reference frame=automatic, 20% frames, sharpened=unchecked, drizzle=off. I don't use any of the advanced features, and no calibration frames (I apply flats live while capturing in SharpCap).
Kristie
