Can someone explain the 3 point polar alignment I don't understand it. More specifically the "select scope point". I don't getba
Basically in a nutshell its kinda like if you imagine GPS when satellites pinpoint your position the more satellites you have the better the accuracy of telling you where you are on earth for triangulation when using maps on your phone
So when you set your scope up and calibrate it by doing the twisting spin dance as it completes it knows where you are standing on earth by the "long and lat" data it collects and is important so when you do the 3 point star polar alignment , the scope aims in the sky and takes 1 image then moves takes another then moves and takes one more , and each shot the scope looks at the star patterns in each of the 3 images this is known as plate solving
once the 3rd image has been taken then the onboard computer of the scope tells the app on how you need to adjust your scope as in which direction has to be changed so you have basically the up and down left and right numbers try and get it close to Zero as possible in green once youve made these adjustments then the scope is as good as polar aligned ie pointing at polaris the north star
also the new feature lets you select the angle you wish to start the 3 pic star alignment off , that feature is handy if you have the sky blocked directly above you by part of your house, balcony or tree or even if there is say some clouds right above you were you cant see stars so selecting another spot in the sky makes polar alignment easier
it is super handy if for some reason you cant see polaris cus your own vision is blocked due to houses or trees ect ect
Edited by Airstrike, 17 May 2025 - 10:32 AM.
