What is causing this block pattern?
5 replies to this topic
#1 pgseye
pgseye
  • Loc: Melbourne, Australia
Posted 16 May 2025 - 02:30 AM
HI All,
Wondering what is causing this pattern after gradient extraction, star separation and stretching. This image was taken on a Fuji mirrorless camera with a Samyang 135 mm lens.
Paul
#2 maxsid
maxsid
  • Loc: Sunnyvale, CA
Posted 16 May 2025 - 03:45 AM
Try to extract stars after the initial stretch (not before)
Edited by maxsid, 16 May 2025 - 03:46 AM.
  • pgseye likes this
#3 Lvansoo
Lvansoo
Posted 16 May 2025 - 03:47 AM
What star removal program are you using?
Both StarXTerminator and StarNet work by dividing an image into "blocks", analyzing each block separately for stars, and then blending the starless image "blocks" back together.
If you're using StarXTerminator, try checking the "large overlap" option before running StarX.
For StarNet, try running star removal after stretching the image. Sometimes that will work.
Hopefully this helps!
- Lyle
  • tectonik, soojooko and pgseye like this
#4 soojooko
soojooko
Posted 16 May 2025 - 06:43 AM
Yep. I can confirm this. I have seen the same grid pattern when using StarX on images with dense starfields. "Large Overlap" fixes it - but also adds considerable time to the process.
  • pgseye likes this
#5 TomC_RR
TomC_RR
  • Loc: Southern Oregon
Posted 16 May 2025 - 08:08 AM
+1 on large overlap with SXT
  • pgseye likes this
#6 pgseye
pgseye
Posted 16 May 2025 - 03:42 PM
Yep - it turns out this was the problem.
Thanks everyone - I don't know that I would have easily figured that out otherwise.
  • Lvansoo and soojooko like this
