I bought an Intes MK-65 off of craigslist, thinking I could have a fun 6 inch mak to play with. Doing some searching for information on these maks, I found what I think is the exact one here: https://www.cloudyni.../#entry12321000. Other than this thread, there does not appear to be much info out there.
This mak does not move the primary to focus, and in addition there are is no external collimation adjustment. There are two attachments for rear, one with a diagonal and helical focuser for visual, and one that reduces to 42mm camera adapter with a non-rotating helical focuser. I'm not the biggest fan of diagonals with only a single screw to hold the eyepiece, preferring brass clamping rings, and seeing that where was little option for an aftermarket focuser (the rear cell uses non-standard 56.5mm threads) I decided to use the camera adapter to take lunar images with a full frame DSLR.
This was mostly successful, but the backlash in the focusing made it very hard to make fine adjustments. In addition, the focuser had about 15mm of travel, and required 42mm spacers to get the moon in focus when the telescope was at different temperatures. As part of a package/lot purchase, I ended up with a feathertouch crayford focuser with 1 inch of travel. I thought that this would make a good addition to the set up, if I could figure out an adapter.
I took some measurements and decided to try to 3d print the adapter in PETG to see if the threads would even work. The focuser was about an M69 diameter with 0.75mm pitch. After some tries, I got the threads to work smoothly and had this result:
I used a baader camera adapter to fit into the 2 inch opening of the focuser. Proud of what I accomplished, I messed with my LOMO refractor for a few weeks before attempting to take my new assembly outside. When I finally did, I found that I couldn't get it to focus! The extra length of the focuser put the sensor just outside of the range required to focus at infinity. One of the issues with this focuser was that the draw tube extended past the mounting flange about 1/4", so I was limited in how close I could mount the adapter to the rear cell.
Searching for another T2 camera adapter that was thinner, I found that I still needed a couple of mm to focus at infinity. Purchasing a slim camera adapter would be another $50-$100 outlay so I turned again to 3d printing to just see if this would work.
I tried a fully printed one I found online, I decided modified the stl to print just the flange with threads for a 48 mm spacer. The result looked like this:
I was able to print this flange side down with no supports and with an indentation to lock to the canon camera. This flange was only 2mm thick, compared to the 9mm of the baader adapters and looked like this:
Taking this out, I could focus with about 4-5mm of room. You can also see how I had to rotate the focuser to fit it next to the battery compartment of the camera. Also with an M48 30mm spacer in the focuser tube, I could also mount the lens further back for terrestrial photography (if desired).
Overall I'm pretty happy with the result and wanted to share. Next project that I tackled was fixing the wobbly finder mount, which was another adventure in 3d printing, and required full removal of the optics.
Edited by manbot13, 16 May 2025 - 10:39 PM.
