** cross posted on r/AskAstrophotography **
Does anyone have a recommendation for a decent scope for a DSO astrophotography that is lightweight enough for my AM5N mount and is decent quality?
I currently have a Orion 104mm EON ED-X2 scope with field flattener but something like M51 is just too small to image effectivly.
I was considering the Celestron XLT EdgeHD 8 but I read somewhere that a Newtonian is a better route to go.
I currently use a Nikon D850 but I have a ASI2600MC arriving soon.
My budget is around $2k but I would go higher if it's worth it. I would like something that is a good companion to my 104mm f/6.25 for different use cases. I would also love if I could find a 10-12" instead but I hear they're just too heavy, but I have seen some people do it on
a AM5N.
Hello jroozee,
Welcome to CN.
If you are talking about a 10" Newtonian at F4, Skywatcher Quatro for example, this is listed at 36.5 pounds. The AM5N is listed for 33 pounds without CW and 44 pounds with CW.
On paper it looks like it would work, however I don't think it is as easy as it looks on paper. Yes CW will be needed, but more will have to be done, I think. That scope is 36" long and roughly 11" in diameter, quite large. That is where the problem lies. Being large. I do not own a scope like that nor an AM5 mount, but I am thinking this scope will have to be somewhat balanced front to rear in the Dec saddle. Roughly finding the balance point on a bench using a round object like a small pipe or maybe a pencil and putting that in the center of the saddle. Next is a pier extension or two extensions for clearance of the tripod legs. The ZWO CF tripod may need to be upgraded to a more stout tripod as well, don't know. Also you will most likely need to anchor the tripod to the ground, a turnbuckle at each leg. Looking / needing stability here. Don't forget about wind, 11" x 36" object can catch some wind in my opinion.
The other side of the story is tracking error and image scale. ZWO 2600 and 1000mm you will have to guide under .78. Another reason stability is needed.
Going from 100mm to 254mm in diameter is huge, a big jump in resolving power and brightness, 650mm to 1000mm is a jump up but not as big as the diameter jump. My opinion.
My recommendation, knowing what OTA you want - find owners with that scope / mount ask them the hard questions. Hopefully some people who have these scopes and mounts will chime in and tell you a thing or two.
Another thing to try, when you get your 2600 camera, crop the image. See how you like it.
My opinion and thoughts, Joe
Edited by Sacred Heart, 17 May 2025 - 02:59 AM.
