Thanks! I used black Canson paper, white charcoal pencil, charcoal stick, and a paint brush. I draw the field stars first. Then I rub charcoal on 600 grit sandpaper to make a charcoal powder and apply the powder to the paper for the background glow of the cluster. Then I fill in more visible stars with the charcoal pencil.
If you are using pencil and paper, you can lightly pencil in a circle and use a blending stump for the background glow instead of powder.
There are several other springtime GC's in the vicinity, like M3, M5, M53, NGC 5694 and NGC 5053. This is the only one that happens to be in Virgo. Wiki says it was "once a likely member of the Sagittarius Dwarf Spheroidal Galaxy." Pretty neat!
Give it a try!
