I use Astrosystems secondary holders in all my Newtonians. They are lightweight and securely hold the mirror. Problem is, the plastic body on which the adjustment screws bear is soft and easily deforms. Over time, the plastic yields and the secondary collimation is lost.
Some designs place a compression spring under the center stud. Tightening the adjustment screws compresses the spring and limits load on the plastic. I chose instead to bond (with 3M 77 spray adhesive) a thin metal disc onto the plastic surface. I placed a small square of duct tape for one of the screws to touch. Tightening this screw creates a small divot in the tape, which prevents the secondary holder from rotating about the center stud.
During collimation, I snug each screw against the metal disc. The screws firmly tighten rather than feel squishy as before. The primary holder has lock screws to secure mirror position. With the enhancement to the secondary holder, the scope should hold collimation better than it did.
Installed in my Meade 826
Steel disc
Edited by bigbangbaby, 17 May 2025 - 02:38 PM.
