Thanks for all the encouraging words! I primarily got the scope for visual observing, but I'm dipping my toe into photography after many years as a night-time "faint fuzzy" hunter. Solar is a whole new and exciting world.
@rajilina, my method for getting that image was pretty ad hoc, compared to the sophisticated methods I've seen experienced folks on Cloudy Nights use (mostly on PC unfortunately). But I wanted something "quick and dirty" without having to 1) spend hours tweaking and 2) buy a PC. I rough polar-aligned my AM5 mount with the wonderful PS Align Pro software on my phone, and used SkyAtlas to start tracking at solar rate and slewed to the sun (which is obviously in the database). I have a B1800 blocking filter on a diagonal (got this one as it seemed the most versatile to do both imaging and visual). I used ASICap to collect several 2000-image runs at different exposures - as I recall the surface image used a 1 msec acquisition, and I played with the gain to make it look the way I wanted it while watching the real-time image. For the prom, I took some higher-gain exposures (maybe longer duration? I don't remember now), getting them to look the way I wanted (which of course blew out the disc). I don't have an ASIAir unfortunately; they seem to be sold out everywhere. So I'm just interfacing directly from the camera to the USB on my Mac, using ASI Studio. I stacked the images with ASIVideoStack and I think I set the stack percent at somewhere around 30%. Again, I was just playing around so I didn't record all the details unfortunately. I clicked the "sun color" box to get the false color, and saved out two images - one that emphasized the disc and one that emphasized the proms.
One big change I think I could make would be to take the rubber feet off the tripod that comes with AM5 and put on the metal spikes to get a more stable base. I was working under a hood attached to the scope, and whenever I moved even a little the whole thing would jiggle. So that definitely affected the image quality.
I then opened the two images in Photoshop, made the prom layer my base layer, made the disc as separate layer, created a layer mask, and used the "burn" tool with a fuzzy brush to erase the top layer and let the prom layer show through. I had to nudge the top layer a bit to get the images to line up just right, then cropped it a little bit to clean up the edges.
Hope this helps! And it would be great to hear any advice from the "pros" (although my guess is that this advice starts with "buy a cheap PC, get AutoStakkert, RegiStax/waveSharp, ImPPG, etc. and get really good at using them...").
Obviously still a lot to learn, but I'm not sure how far down this very, very deep image processing rabbit hole I want to go...
Best,
Jaimie
