Astromania 10mm 82* review
21 replies to this topic
#1 UnityLover
UnityLover
  • Loc: Suffolk County, NY
Posted 18 May 2025 - 05:33 PM
So far, so good. The field is 82 degrees, though it's not as much as I thought it was. 82 degree eyepieces don't live up to the hype I thought ig.
It's a nice weight to it, only a tad heavier than my 18mm. Looks nice as well.
Tomorrow I'll use it in the field, and I'll compare its sharpness on the edge of field, at the 82 degree mark and 65 degree mark, and at the center, versus my 18mm 65 degree widefield eyepiece.
  • T1R2 likes this
#2 CeleNoptic
CeleNoptic
  • Loc: Mid-Atlantic, Bortle 7
Posted 18 May 2025 - 06:25 PM
Celestron Luminous in a different body. Same as Sky Panorama etc. At 65° in F/5 should be OK, at least what Ernest's bench test has showed.
  • UnityLover likes this
#3 UnityLover
UnityLover
Posted 18 May 2025 - 06:38 PM
Yea ik I've read them, but I wanna ACTUALLY see it if yk
#4 RichA
RichA
  • Loc: Toronto, Canada
Posted 18 May 2025 - 06:49 PM
  • Procyon likes this
#5 MrsM75
MrsM75
  • Loc: 34° N, 117° W
Posted 18 May 2025 - 07:52 PM
It is the clone of the Luminos. What about it that you didn't like? You do have a fast scope though, so you probably need something like Televue for outer edges correction.
3a1d1f39-c80c-4299-a24d-bb811c8b1bea.__C
#6 UnityLover
UnityLover
Posted 18 May 2025 - 07:53 PM
From all the hype I felt 82 degrees would be wider.
It's still wide, certainly an improvement.
Keep in mind this is from holding it up to my eye. Haven't tested it yet.
#7 UnityLover
UnityLover
Posted 18 May 2025 - 07:54 PM
I haven't looked through it yet, other than holding it up to my eye. I just thought 82 degrees would be wider than I thought. It's still good, but I had high expectations I guess.
#8 MrsM75
MrsM75
Posted 18 May 2025 - 07:59 PM
It is ALOT wider once you see it under the sky, looking through it against a white wall, No. You need to get out in the sky to see it.
I can tell you this, I have the most beautiful view of the Orion Nebula with this 82 degrees eyepiece.
I did end up return it because it was way too heavy for my 90mm aperature scope, it literally vibrate my scope, it a 1 lb (16 oz) eyepiece. I got the 10mm Luminos one.
#9 UnityLover
UnityLover
Posted 18 May 2025 - 09:26 PM
Yeah the luminos is a lot heavier than this one. I'll give reports tomorrow night or Tuesday.
#10 RichA
RichA
Posted 18 May 2025 - 09:59 PM
Silly that they'd designed it with an aluminum skin that really had little to no purpose.  This is a problem not with just eyepieces, but some telescopes today that are overbuilt so they look good but whose functionality isn't improved by it.
#11 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 19 May 2025 - 05:44 PM
I wasn't aware that 'waterproof 'meant water is allowed to enter the eyepiece.grin.gif
These Chinese companies (Barsta in this case) need to hire English speakers to write their ads.
For instance, they have a 70° line called "SWA".  The 82s should have been 'UWA',
"Compact" is also a relative term.  "Small and light" would have been more appropriate.
"Allows any water enter the interior and always enjoy an unobstructed view" should have been, "Prevents moisture from entering the eyepiece, yielding a clear image always free of internal fogging or mold"
Edited by Starman1, 19 May 2025 - 05:47 PM.
  • Mike W, T1R2 and MrsM75 like this
#12 UnityLover
UnityLover
Posted 19 May 2025 - 09:40 PM
I tried it tonight.
The 82 degrees us MUCH more pronounced at night. Compared to the 65 degree, stars are tighter all around. Even at the very edge, it's the exact same as the 65 degree. The 65 degree is cometlike from the outside 20% I'd say, the 82 degree is cometlike from the outside 10% perhaps. Tested on Vega. It is nice and lightweight, but certainly not compact. No comment on the waterproofing.
#13 UnityLover
UnityLover
Posted 20 May 2025 - 06:07 PM
Also, EOFB is present, but its mainly because of the high light pollution.
#14 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 20 May 2025 - 06:10 PM
Also, EOFB is present, but it's mainly because of the high light pollution.
I've wondered if this might be the case as to why I don't see EOFB in the 4.5mm Morpheus while others do.
#15 MrsM75
MrsM75
Posted 20 May 2025 - 06:41 PM
How much did you buy it OP? I had a 30% off coupon for this 10mm
#16 UnityLover
UnityLover
Posted 20 May 2025 - 07:15 PM
15% off, with tax about 102.
#17 MrsM75
MrsM75
Posted 20 May 2025 - 07:24 PM
You should see a bigger field of view of the sky though. Try it at the Beehive in Cancer when sunset.
I actually like it tbh, it just it heavy and big (even with it being smaller than the Luminos), but my scope is small aperature so it hard on my scope size.
#18 MrsM75
MrsM75
Posted 20 May 2025 - 07:36 PM
I mean, their English sound like me Sir, lol
I actually like this clone of Luminous, it just the eyecup is tough to fold down. I wear glasses so I always need the eyecup down.
#19 Procyon
Procyon
  • Loc: 37º N | 45° N
Posted 20 May 2025 - 07:47 PM
gets you the really big view
#20 CeleNoptic
CeleNoptic
Posted 20 May 2025 - 08:08 PM
BTW, you can unscrew the eyecup to get more eye relief or install DIY eyecup instead. They designed so to attach camera to eyepieces for AP. Folding down isn't a good thing; I've seen in CNC similar eyepieces with the eyecup broken.
#21 UnityLover
UnityLover
Posted 21 May 2025 - 11:46 AM
It does give a bigger fov, much better than my other eyepieces and it's amazing under the sky.
#22 MrsM75
MrsM75
Posted 21 May 2025 - 07:10 PM
If you like 82 degrees, the AstroTech 82 degrees SWA https://astronomics....=Astro-Tech UWA
That the series. It $119, never go on sale, but that the price. There other focal length in there you might like.
Reviews actually say the AstroTech 82 degrees is better than the Astromania/Luminos 82 deg (the one you have).
But reviews to me it subjective, whether people like to admit it or not, we all have our bias, and we form our reviews by our personal experience. What work for one people might not work for others.
So you need to try one yourself, don't just go by reviews.
