I am starting to think about getting a longer scope to go along with my redcat51. I like the redcat but its quite wide and this summer I want to do as much nebula & galaxy imaging as I can.
So I have been browsing classified in my area and notice some scopes come with a reducer. Now I think I understand the application; they reduce the focal length but increase the focal ratio.
Why would I want this for DSO imaging with filters? (particularly NB) where my exposures are going to be quite long - i.e 120-300s am I not just losing focal length and not getting the benefit for shorter exposures? wouldn't I want to go for length over speed in this instance?
Secondly, whats a good option for DSO targets to compliment my Redcat? I am on a bit of a budget, so looking at used & something up to approx $1000 would be my spend limit
You really need to understand some basic things to do this well.
The first is field curvature. With an ordinary doublet or triplet, the field is curved, and needs to be flattened. Your Redcat does this internally.
If you get a telescope that's a doublet or triplet, you need a field flattener. The overwhelming majority of these also reduce the focal length. So when we talk about a 0.8X reducer, what we're talking about is a field flattener that also reduces the focal length by 0.8X. 1.0x flatteners exist for some scopes, but they're rare. A number of scopes include the flattener internally. That's a significant convenience.
The reduction SHORTENS the exposure needed with a narrowband filter, another reason people use reducers(/flatteners).
Your Redcat is quite short at 250mm. Doubling that to 500mm would be good, you probably don't want to go too much longer yet. I'll give two examples, somewhat over your budget, new.
The first is a doublet with a matching flattener(/reducer). 0.8X. Matching the flattener is good, field curvature varies. The second has an internal flattener.
https://astronomics....num-f-7-doublethttps://astronomics....t-apo-refractorThe second. "Self-flattening design. No need for a separate field flattener"
https://agenaastro.c...-telescope.htmlGetting a doublet or triplet that needs a flattener is cheaper. But flatteners need to be spaced properly, and it's not trivial.
Edited by bobzeq25, 19 May 2025 - 11:03 AM.
