Anyone Using the ASI120MM Mini?
12 replies to this topic
#1 saemark30
saemark30
Posted 19 May 2025 - 09:46 AM
Seems this device would work for a planetary and deep sky camera.
Anyone tried using it other than for guiding?
#2 sozen
sozen
Posted 19 May 2025 - 09:51 AM
the ASI120MM/C was a flagship for them for like half a decade; however, they only produced the ASI120 with USB2.0 for about a year before going to 3.0.  This will limit its utility for todays standards with the 120 mini being usb 2.0 and lower frame rates
Edited by sozen, 19 May 2025 - 09:52 AM.
#3 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 19 May 2025 - 10:13 AM
In fact ASI120MM mini is more aimed at guiding camera.
There are more suitable cameras for planetary imaging (and deep sky as well)
For planetary imaging I recommend reading the FAQ.
  • Jim Waters likes this
#4 flightlogic
flightlogic
  • Loc: Flagstaff, Arizona 7000 ft. MSL
Posted 19 May 2025 - 10:35 AM
I suspect it may be the most common guide camera out there.  At least from what I have observed in the category of beginning deep space photography.
#5 BlueMoon
BlueMoon
  • Loc: South Central Idaho
Posted 19 May 2025 - 10:39 AM
Try it and see. What others use it for doesn't mean it can't be used in other imaging configurations.
  • Juno18 and matt_astro_tx like this
#6 soojooko
soojooko
Posted 19 May 2025 - 10:47 AM
ZWO also made a variant called the ASI120mm-s which is USB3. That's what I use. But I'm not sure if it's still available.
Edited by soojooko, 19 May 2025 - 10:48 AM.
#7 matt_astro_tx
matt_astro_tx
  • Loc: Dallas, Texas
Posted 19 May 2025 - 10:57 AM
This! Personally, I wouldn’t recommend the 120MM Mini for what you’re proposing… but that doesn’t mean you shouldn’t try it for yourself. Experimentation is a tremendous way to learn about your equipment - both its capabilities and limitations. We can all sit around and tell you what we think but maybe you’ll find a way to make it happen and surprise us all.
If you’ve already got this camera then what have you got to lose?
If you are looking for a camera to purchase then yes there are far better ones.
  • BlueMoon, Erik30 and flightlogic like this
#8 saemark30
saemark30
Posted 21 May 2025 - 08:45 AM
How do I install the 120MM mini and what software do I need?
I just received a used one with no instructions.
#9 AdrianoMS
AdrianoMS
  • Loc: Volta Redonda, Brazil
Posted 21 May 2025 - 08:53 AM
You need to download the drivers from the ZWO website first. Will you use the camera for guiding or imaging?
#10 saemark30
saemark30
Posted 21 May 2025 - 09:46 AM
I would like to do some imaging now but guiding later on.
#11 tectonik
tectonik
Posted 21 May 2025 - 01:00 PM
Follow the directions on this web page:
https://www.zwoastro.com/software/
Also has image capture software.
Tek
#12 saemark30
saemark30
Posted 23 May 2025 - 11:13 AM
Does using PHD2 require installing the ASCOM driver?
#13 Spaceman 56
Spaceman 56
  • Loc: New Zealand
Posted 23 May 2025 - 05:18 PM
the ZWO-120MM is a mono camera that does not take colour pictures.
most people will use it as a guiding camera, often attached to a small Guide Scope. like a ZWO 30F4 or similar.
you could attach it to any telescope that you want to, and take pictures, but they will be Black and white.
to get a colour picture out of a mono camera you would need to add Coloured filters and take at least 3 sets of images, and combine them together.
the other option is to buy a Colour Camera and take Colour pictures without all the fuss, and use the 120mm as a guide camera later on.
Edited by Spaceman 56, 23 May 2025 - 05:19 PM.
