Thank you Joe. Good information and I do use SharpCap for polar alignment and always set to "Excellent". Last night the PA was actually dead on. I'll start from scratch again with the AT72 and calibrate and run the assistant. The mount is balanced both ways but the total kit is probably close to 45 pounds.
One of the mysteries to me with the G11G is backlash and how to account for it.
This is some of the notes I've saved from things I've read about PHD2 and the G11G.
>Set TVC to zero (0) for the mount. You want PHD2 to
handle all backlash compensation. TVC=0 means the
mount backlash compensation is turned OFF.
>Try 3 second exposures (I've been using 2 seconds and tried 2.5 and things got worse).
>Run Guiding Assistant (GA) for at least 6 minutes. Accept the
GA recommendations for DEC and RA minimum move.
>The default target box of 15x15 pixels is too small.
Set it to 50x50 (maximum)
>Force Calibration every night (Shift-Click); must be
within 10 degress of the celestial equator (Dec=0)
for calibration.
>Always do a NORTH bump before starting calibration (I've not been doing this).
>On the history graph turn on (select) CORRECTIONS and
TREND LINES; good trend lines should be horizontal
>Set aggression at 55-70.
>Leave MAX move at 2,500ms and set MIN move to 0.15.
>Don't trust declination correction in PHD2 (leave off).
