Can someone check my math please.
I'm looking to do a slight adjustment to my camera tilt. NINA (Hocus Focus Aberation Inspector) says to move one corner towards the objective 28um. I'd like to know how many degrees to turn the grub screw, so I've done some math. This isn't my area of strength, so if I could lay this out and have someone check it over, I would greatly appreciate it.
Equipment is TOA-150B with Tak 4" focuser and Oasis Rose electronic focuser. ZWO ASI6200MM, EFW, OAG-L.
Focuser Steps per Rev = 27000
1 Revolution (mm) - measured = 24.4
Tube movement mm/Step = 0.000903704
Tube movement micron/Step = 0.903703704
M4 Grub Screw pitch rev/mm = 0.7
M4 Grub Screw pitch rev/micron = 700
M4 Grub Screw degree/micron = 1.9
Micron to move = 28.7
M4 degrees = 55.8
I've attached a small spreadsheet with these calcs.
Thanks in advance!
