Grand Canyon star party 2025
#1
Posted 19 May 2025 - 11:55 PM
#2
Posted 23 May 2025 - 03:53 PM
You can set up a scope anywhere you want as long as you are respectful to the park.
Yavapai Lodge is dark but there are lights. Every light in the park has been documented to ensure it the skies remain dark. You can have elk and deer anywhere in the park, as long as you leave them alone you are fine.
The parking lots at Yavapai lodge are not ideal as they are seated in the pines. You can have good views but your horizon is low. The parking lots at the visitor center have great horizons and after dark no one is out there usually. I wouldn't be surprised if others are out there a night or two before but I don't believe they block off the main parking lot to leave equipment out until the first Saturday.
Your best bet will be the parking lots behind the visitor center where the star party takes place. The upper of the two as the best horizon, that is where I usually set up every year.
#3
Posted 27 May 2025 - 12:47 PM
#4
Posted 27 May 2025 - 04:09 PM
I would probably bring the ST120. You will have the Milky Way rising early in the evening and becoming nearly overhead by midnight. A short tube refractor would allow you to cruise the Milky Way and the collection of dark nebula and other wide field targets. But ultimately, whatever works for you.
Omega might be too low by the time the star party occurs. Now is the best time for Omega here in Arizona and its only in a good position for a few weeks.
#5
Posted 29 May 2025 - 07:23 AM
