dew heater and pegasusAstro powerbox
Accessories Astro Tech Equipment
12 replies to this topic
#1 Gaiden
Gaiden
  • Loc: France
Posted 20 May 2025 - 11:36 AM
Hi!
I own a Pegasus Astro Pocket Powerbox Micro and I can’t figure out how to connect my dew heaters to the correct ports — see the photos below.
Can anyone help me?
#2 MichaelACG
MichaelACG
Posted 20 May 2025 - 12:06 PM
You need a dew heater 12V with a Male RCA plug - like this one: https://www.apm-tele...52cm-length-11w
Your plugs will not fit. My dealer said that there are no adapters ... I have to purchase a new dew heater. I did.
#3 tectonik
tectonik
Posted 20 May 2025 - 01:20 PM
I have been searching the net for an adapter but have yet to find one.
Please share the manufacturer's name.  Never saw one with a barrel connector until now.
Tek...
  • CraigR likes this
#4 Yomamma
Yomamma
  • Loc: North Central Florida
Posted 20 May 2025 - 01:28 PM
Order regular RCA male plugs from Amazon and solder them on to the correct length.  That is what I did and you have no hanging wires then they are all the correct length.
#5 Lucky 777
Lucky 777
  • Loc: Carlisle PA USA
Posted 20 May 2025 - 10:41 PM
Make sure the heater straps are for 12 volts and not 5 volts.
#6 CraigR
CraigR
  • Loc: Iowa, US
Posted 21 May 2025 - 11:28 PM
It's really hard to tell what kind of connectors those are. IF the dew heaters are 12V, and if those are DC barrel connectors, something like this might work: https://agenaastro.c...or-dew-heaters/
#7 Cliff Hipsher
Cliff Hipsher
  • Loc: Disputanta VA
Posted 22 May 2025 - 06:08 PM
Agena Astro has DEW Not heaters in different lengths.
#8 The_boots
The_boots
  • Loc: SE Michigan
Posted 22 May 2025 - 08:16 PM
It seems strange that there are no adapters. You should be able to fashion some yourself by connecting these:
https://www.amazon.c...s/dp/B097N9TLT5
To these:
https://www.amazon.c...r/dp/B07TGGTXWH
Only tool you'd need is a screwdriver.
I'm not sure why they decided to use RCA in the first place. It's NOT a power connector. I guess it was low current enough not to worry about, but still. Maybe someone out there knows the reasoning.
Edited by The_boots, 22 May 2025 - 08:18 PM.
  • Gaiden likes this
#9 Cliff Hipsher
Cliff Hipsher
Posted 23 May 2025 - 07:13 PM
Until the  (shudder) 5 volt  USB heaters came out, every heater I've ever seen had an RCA connector.   Back in the day I used a variable PWM driver board and built a heater controller with RCA output ports.
When I got my first Air Plus I took some of my old Dew Nots, cut the RCA plugs off and soldered on right angle Male 5.5mm x 2.1mm plugs.  The coolest part is I cut the cables to length which cleaned up the cable management.  I have 3 rigs setup that way...
Edited by Cliff Hipsher, 23 May 2025 - 07:14 PM.
#10 Gaiden
Gaiden
  • Loc: France
Posted 24 May 2025 - 02:45 AM
To these:
I'm going to do this.
thanks
#11 Cliff Hipsher
Cliff Hipsher
Posted 24 May 2025 - 08:22 PM
I thought about using connectors like that, but then again a solder connection is always better than form of screw/clamp connection.
Another issue is the individual wire strands are not supported/restrained which exposes them to bending and eventual failure.
Easy is not always better...
#12 archiebald
archiebald
  • Loc: Japan N36°17'37"
Posted 24 May 2025 - 09:27 PM
Hi!
Can anyone help me?
Gaiden, I have a much more simple solution, and more local to you being in France.
I'm assuming your dew heaters are SVBony and come with the optional 3-level power switch?  If so then the connection from the dew heater side is female 5.5 x 2.1mm.
You just need one or more of these from First Light Optics.  I used the same on my rig.
Lynx Astro DC2.1mm MALE to RCA for dew controller,
https://www.firstlig...controller.html
Edited by archiebald, 24 May 2025 - 09:31 PM.
  • Miguelo and The_boots like this
#13 The_boots
The_boots
  • Loc: SE Michigan
Posted 25 May 2025 - 10:10 AM
Two things:
I agree that solder is better, and if it were me, I'd actually suggest using the combination low-temp solder + heatshrink tubes you just hit with a hot air gun, since they also have some waterproofing.
On the other hand:
1) I didn't want to assume what tools they have or what their comfort level is with things like soldering. The option I gave is both easy AND requires no additional tools beyond a common screwdriver.
2) Since this seemed to me to be a bit of an experiment, this seemed like a good way to see if things worked before coming up with a more permanent solution.
Easy isn't always better, but that doesn't mean it's always worse! 😉
Edit:
Re archiebald's post: I THOUGHT it was crazy that nobody had one of these ready-made!!
Edited by The_boots, 25 May 2025 - 10:12 AM.
  • notdecraw likes this
Also tagged with one or more of these keywords: Accessories, Astro Tech, Equipment
